Cam Recommendation 427 SBF
Autopart101
Post by Autopart101 »
Looking for input on what cam profile to run in my 427. I want to run a SR set up.
4.040 Bore
4.170 Stroke
AFR220 heads flow around @330 @ .700 lift
11-1cr
Super Vic intake
Carb 950DP
1 7/8 LT header
Trans TKO600
3.73 gear
Thanks!
Re: Cam Recommendation 427 SBF
Post by MadBill »
What kind of driving/racing will you be doing and how do you feel about high lift/high maintenance valve gear vs. many, many worry-free miles?
Autopart101
cstraub wrote: Wed Dec 13, 2017 4:19 pm What rpm do you want to make peak HP?
6,400 6,500
Autopart101
MadBill wrote: Wed Dec 13, 2017 5:02 pm What kind of driving/racing will you be doing and how do you feel about high lift/high maintenance valve gear vs. many, many worry-free miles?
I have a H/R 242-254@.050 .600 lift and a set of OOTB vic Jrs on it now. Go to the track 5-10 times a year. Drive around town less than 1,000 miles a year. The high lift maintenance is not a problem.
Casper393W
Post by Casper393W »
What LSA is the cam ground on?
Autopart101
Casper393W wrote: Wed Dec 13, 2017 7:21 pm What LSA is the cam ground on?
It's been 17 years. I think its 112-114.
mjtorb
Post by mjtorb »
260-270 at .050 range. keep the lift in the .680-.720 range. had a very simalar set up. ran very well
CamKing
Post by CamKing »
Assuming 1.6 rockers
Cam# F351w, R77424-110
260/260 @.050"
.424"/.424" Lobe Lift
110 LSA
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
blykins
Post by blykins »
You don't need a lot of duration for a 6500 rpm peak.
I have ran this exact combo on the dyno.
I'd be at 254/258 @ .050", 290/294 adv, .672"/.672" on a 1.6 RR, 108 LSA on a 108 ICL.
Billet steel core, standard base circle. Wouldn't be a spring eater, easy on valve train.
Lykins Motorsports
brent@lykinsmotorsports.com
www.lykinsmotorsports.com
www.customfordcams.com
CamKing
Post by CamKing »
blykins wrote: Thu Dec 14, 2017 10:51 am I'd be at 254/258 @ .050", 290/294 adv, .672"/.672" on a 1.6 RR, 108 LSA on a 108 ICL.
If that 290/294 is at .020", that's basically just an under-area'd version of what I recommended, but on a 108.
My recommendation is 292/292 @.020".
He wouldn't be giving up any torque, would make more HP, and it's easy on the valvetrain.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
blykins
Post by blykins »
CamKing wrote: Thu Dec 14, 2017 12:08 pm
...would make more HP....
Maybe. Maybe not.
Lykins Motorsports
CamKing
Post by CamKing »
blykins wrote: Thu Dec 14, 2017 12:32 pm Maybe. Maybe not.
You're about 20,000 dyno pulls short of being able to make that assumption.
There's no "Maybe" about it. My recommendation would put 20hp over that lazy cam you recommended.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
blykins
Post by blykins »
Hey, let’s all just be jerks today.
For one thing, you don’t know how many dyno pulls I have made.
The second thing is that I’m getting real sick and tired of “cam grinders” thinking that just because they come up with it it’s the best thing in the world. I’ll be the first to tell you that theory doesn’t always equal reality.
So I take it from your response that you’ve dynod an engine exactly like the OP has, with your recommendation and then a cam exactly like I recommended as well? Because that should be the only reason why you should come on here and show your ego like you did.
Maybe we should each grind it and send it to him. The only way you learn is to try stuff back to back. Way too often do people just buy one camshaft and are totally happy with it, not realizing that there is actually something out there much better.
I am confident in what I posted, but there is no way that I’m stupid enough to think that every cam I spec is the absolute best choice for a customer, or foolish enough to belittle someone else’s experience level over a discussion.
Lykins Motorsports
CamKing
Post by CamKing »
Wow, someone if feeling a little big for their britches today.
Settle down. You don't have 1/100th of the knowledge or experience I have. It's not even debatable.
Your overwhelming arrogance is why I stopped trying to help you a few years ago. You're just too smart to listen.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
blykins
Post by blykins »
No sir, I'm not feeling big for my britches. I certainly didn't come in here shooting off both barrels, aiming at everyone else's experience levels. Remember, you're the one that singled my post out. I didn't take a shot at yours.
So my overwhelming arrogance is why you stopped helping me years ago? Did you forget that you sold me a camshaft this year? :lol:
Does this look like I have overwhelming arrogance to anyone else out there?
To: jonescams@bellsouth.net
Sent: Tuesday, May 30, 2017 11:23 AM
Subject: Need recommendation and price.....
Mike, hope you're staying busy and doing well.
I have a 434 inch Clevor that I built for a drag race customer. He
doesn't have the car sorted out entirely yet but has already made plans
to spray for next year and wants to get parts here for when it comes
back for a freshen-up this fall.
Current camshaft is a custom Comp piece, 261/273 @ .050", 112 LSA on a
110, .471"/.471" lobe lift, running 1.8 T&D race rockers.
On the dyno here, it made 777 hp @ 7000, 630 lb-ft @ 5500.
*4.155 x 4.000, with a 6" rod
*55mm on all 5 journals, roller cam bearings
*.904" lifter bores
*Heads are CHI 3V heads, about 245cc intake port volume. 2.250"
intake/1.710" exhaust.
*Intake flow is: 212 @ .300, 276 @ .400, 320 @ .500, 347 @ .600, 373 @
.700, 384 @ .800, 391 @ .900
*Exhaust flow is: 160 @ .300, 199 @ .400, 225 @ .500, 245 @ .600, 256 @
.700, 265 @ .800, 275 @ .900
*Compression ratio is 13.5:1
*Intake is a CHI 3V 225 cc intake, ported, with a 2" Super Sucker 4150
to 4500 adapter, with a 1100 cfm Dominator
*It is a vacuum pump motor
*Running a Powerglide with a 1.58 1st gear and a 5500 stall.
*Vehicle weighs 3000 lbs with driver ('69 Mustang)
*Running VP C12 fuel
*Headers are 2.125" diameter
*Running 1.550 Manley Nextek springs, 300 seat with 800 open.
Here's what we are going to change and what we'll need another camshaft for:
*Going from 13.5:1 to 14.5:1
*Adding 400 hp worth of spray
*Changing intake from current to a CHI 3V intake, ported, but with a
4500 flange. No adapter spacer.
I bought an additional camshaft last year when I built the engine to try
on the dyno, but with it making almost 780 hp, we decided to not try
it. His previous engine was a 575 hp 408C and with an all new
chassis/suspension, we weren't looking to optimize the combo. The cam
I have on the shelf is a custom with Comp HXL lobes, 272/280 @ .050",
with .800" gross lift, on a 108 LSA.
Thanks for your help.
Go take your Geritol, drink a Mt. Dew and calm down.
Lykins Motorsports
