My last post on the subject as well. I hope you, BOOT have done your due diligence and determined what you're hearing here is correct.
I sense you are young and seeking knowledge and I commend you greatly for your quest for knowledge. My apologies if I'm wrong.
Buckling failure of a column under lateral dynamic loading is one of the most vexing problems looking for a strong analytical solution out there. If you are not busy for the next forty years or so and interested enough there is a life's work ahead of you.
Pushrod shape
Re: Pushrod shape
Boot,
I think it is safe to say that a round PR is gives the best strength/weight ratio for what we use PRs for.
People over several decades have had the time & money to experiment with different shapes & cross sections...& are still using round tube. Got to be a message there...
Re: Pushrod shape
i speculate there are 2 main reasons why we use a round tube pushrod. 1 is it works fairly well, 2 it is cost effective.Geoff2 wrote: ↑Fri Dec 15, 2017 3:33 am Boot,
Re: Pushrod shape
with effectively a ball joint at either end it makes sense for it to be symmetric about every axis i.e. round
Re: Pushrod shape
Think about what you mean by "better". A round pushrod is a column that has the same loading characteristics in any direction AND it's a simple solution. If you constrained a pushrod in one direction it could be non-symetrical and stiffer in another direction. A 2-piece pushrod with the joint sliding in a fixed guide could be MUCH stronger because the column is half as long.
Tubular pushrods have developed because they're simple, predictable, manufacturable, and good enough.
Dave
