305 tq suggestions
cv67
305 tq suggestions
Post by cv67 »
May be picking up a 70 1/2 ton
Nice truck but has a 305 recently rebuilt. Has a performer on it
Thinking of a cheap flat tappet, perhaps look for a deal on a set of heads & put some work to them
Cheap upgrade til 400 drops in my lap (shoulda never sold it)
was thinking something like a 256 isky soemthing along those lines? Cheap headers?
Eddy 1406 perhaps?
bigjoe1
Show Guest
Show Guest
Re: 305 tq suggestions
Post by bigjoe1 »
Don't waste your money---VERY LITTLE DIFFERANCE-- Rear end gears or smaller tires- Dual exhaust would help
JOE SHERMAN RACING
F-BIRD'88
Post by F-BIRD'88 »
If uou want a 305 sbc to make the torque of a 400 cid motor
supercharge it.
cv67
Post by cv67 »
that would be like a boob job on a midget. Interesting but useless lol
If it comes to fruition Ill just keep my eyes open for something larger to start wtih dont want anything other than a stockish build wiht a torque cam thats it. Getting away from EFI...
CGT
Post by CGT »
F-BIRD'88 wrote: Mon Dec 11, 2017 2:57 am If uou want a 305 sbc to make the torque of a 400 cid motor
supercharge it.
Or a couple turbo's, meth injection, and a 6 speed manual tranny would help that $100.00 305.
rfoll
Post by rfoll »
A1970 1/2 ton likely came with a 3.73 rear gear. A properly sized long tube header will help , and you will have them for the new engine.
RevTheory
Post by RevTheory »
I know when someone mentions a 305, everyone defaults to "don't waste your time!" but I have a little different opinion. I say, if it gives you something to put your hands and mind on and makes the little guy a little more tolerable while you wait for the bigger engine, go for it.
I'd consider rolling the seats into the bowls, maybe skinny down the guide boss a little and stay out of the runner. The exhaust cleans up really well too so you could probably ditch the large exhaust split.
I think 256 is probably about right but with factory seats, I'd probably tighten up to a 107 or 108 LSA. I doubt if I'd go the Isky route unless they have something more modern than the "Mega-Cam" series. Howard's Cams sounds like they have some that won't slap the valves shut like a Comp Xtreme.
Hell, give it a run and see what shakes loose.
rfoll
Post by rfoll »
Unless the builder put some effort into the rebuild, the 305 could have lost a chunk of compression. With prebulider piston another .020" down in the hole and a head gasket another .020" thicker, the ratio could be in the 7s.
F-BIRD'88
Post by F-BIRD'88 »
cuisinartvette wrote: Mon Dec 11, 2017 7:48 am that would be like a boob job on a midget. Interesting but useless lol
Too bad as a 305 with hot rodded TPI efi will max the N/A torque output.
Any cam you put in it req higher cr too.
As said I bet your real Cr is lower than stock now,
but ripe now for supercharging.
cjperformance
Post by cjperformance »
F-BIRD'88 wrote: Mon Dec 11, 2017 3:59 pm
:shock: what ! I would have thought it needed 2 x 4bl's or 1.5 QJ's !? Are you ill !? J.k. :lol:
F-BIRD'88
Post by F-BIRD'88 »
The 2x4's or 1.5 qjets would rock on a MP122HH Magnacharger on this 305 pickup.
Ported 350 TPI (083) heads, headers, generic 214-224 .442 .465 112 cam. on a stock shortblock.
A lot of truck fun. More fun than a 400
You'd have a whole new opinion of 305's.
"Hold on Newt, we're headed for the alfalfa!!"
autogear
Vendor
Post by autogear »
If you can find a set of late 90s -059 casting Vortec 305 heads...they flow very good for smallbore iron heads. The other cheap heads would be a set of -113 aluminum vette heads (or ZZ4 take off heads).
cjperformance
F-BIRD'88 wrote: Mon Dec 11, 2017 4:55 pm The 2x4's or 1.5 qjets would rock on a MP122HH Magnacharger on this 305 pickup.
Low comp small cube engine, if its a good runner just do a fresh set of valve springs and a basic 6-8lb blow thru turbo or supercharger setup. Norhing exotic keep it cheap. Aim the setup to be on song between 1500 and 5000 and as a streeter it will be a pretty surprusing bruiser.
No TQ cam or headers will put it anywhere near what a little boost at low rpm will.
cv67
Post by cv67 »
doubt its anything other than a stock rebuild...puting that one on the back burner
Next contender 76 half ton shortbed 350/turbo 350 has a performer, long tubes, eddy carb
little ligheter this ones pretty sharp have to get around smog somehow.
I like the mega cams for some reason dont have a good opinion of the XE.
This one Ill probably grab if hes as serious as he says..
Maybe nothing bigger than a 264-270. Trying to be conservative...max rpm Id say 5ish
Its going to be a daily and dont want to screw with it much.
Whatever heads are on it will just clean em up and run it unless a nice pair falls into my lap cheap
Forgot..hava pair of phase 2 heads sitting at the machine shop still if they havent tossed them out.
Kind of excited geting something I can fool with and never have to take anywhere to guess at a code.
HEi, mech fuel pump simple carb hard to go wrong. I trust that more than GM electronics.
rfoll
Post by rfoll »
No way I would choose a 76 over a 72. I have had both. The 73 and later are bricks, 67-72 are classics. If you are built kind of long, over 6" tall, the later trucks may work better for you though. Since you are dealing with sbc motors, the options are limitless. Choose the truck you like, and build the engine that suits your needs. I put a 400 with Vortec heads in my C20, and it puts a smile on my face just going to the parts store. Good torque amd MPG too.
