Bmod 1960 spacer from speedway question
Is there anything special about the 135-1960 spacer that has to be run on the B-mods for the concept engine or is there one somewhere that is cheaper than $80? Seems high considering i have atleast 4 different spacers of that design already. And im only wanting to try the 4 barrel on my "spec" engine this upcoming season as it is "concept" legal.
Re: Bmod 1960 spacer from speedway question
Since this appears to be a Wissota spec piece with a spec number on it, and likely that means
someone is paying Wissota for the privilege of making and/or selling it, why would you expect
to find a new one cheap? Find a used one or make your own forgery. If
, then stick one of your 1" spacers with matching 1.693 holes on your engine and don't end up where you'll be teched on race day.
Wissota is known for teaching the low hanging fruit and the top of the engine is a prime target...
All it is is a four hole spacer yet it has to be something special? What an idiotic rule.
Wissota and IMCA are full of them... the funny thing is so many racers don't have a clue.
