roller rockers vs contact tip rockers
Re: roller rockers vs contact tip rockers
Just to add some more examples of varying rocker ratios, through out the lift cycle.
Here is an example of same lift at TDC, but more lift at max lift. 1.7 alum rockers: 0.123"/0.607"; 0.122"/0.613".
Here is an example of same lift at TDC, less lift at max lift. 1.8 rockers: 0.126"/0.649"; 0.127"/ 0.638"
Not enough people plot out valve lift profiles, it's one thing to check some opening and closing points or centrelines but if you want to understand performance and effect of different parts you need to see and compare the whole curve.
HeinzE
your interest is in a motorcycle, and for such an application you need to keep in mind one very important aspect - a roller ended rocker arm will bring with it unacceptable weight just where it's not needed, on the valve side of the rocker pivot.
For your Aermacchi you are far better to stay with the stock rockers, but if you take a page out of BILL-C's notebook and re profile the pad, you can further improve the contact.
For those who have access to Prof. Blair's software 4StHead, this reprofiling is described and calculated under sub program #7.
Re plotting the valve lift profiles, be aware that the profiles measured from a non running engine will differ when the engine is running, with the biggest difference being in a delay (lag) of the exhaust valve opening as compared to the static measured. and can with a pushrod engine in extreme cases be as much as 20 crankshaft degrees
To add to that, the oil film is the least effective possible in that location because there is nothing to stop the oil from squishing out under the loading and movement.exhaustgases wrote: ↑Fri Dec 08, 2017 6:45 pm Its pretty much simple trigonometry, a the end of the rocker tip on the stem has a wipe,,,wiping motion across the contact area. And for argument if a non roller rocker had high contact pressure and no lubrication that motion is transferred into side loading the valve stem.
I would also add that I have never seen a factory rocker that even came close to behaving like some have described as their theoretical behavior in real life.
Regarding the roller mass at the end of the rocker, what other material that's lighter is going to be at the end of that rocker? It's going to be steel or iron anyway. That argument is moot, especially in a pushrod engine that has typical pushrod rpm limitations.
I would also add that it is virtually assured that nearly all of us here are running roller rockers in our own vehicles, if available.
As I previously mentioned, the roller could be better if it rolls, but won't be worse even if it doesn't .
All IMHO, of course.
I run a pushrod motorcycle application fairly similar to Heinz, as shown earlier in this thread, and my T&D roller rockers are working admirably in the performance application.
NASCAR circa the mid-late 2000s (TRD and Ford) were using rockers with no roller. They were either steel rockers with DLC coating or aluminum on the radius pad. Not sure if they're still used. Warp can comment.
Modern finger follower systems don't use rollers on the valve side, and DLC is common in those applications.
https://www.ebay.com/itm/Del-West-Chevy ... 2206655309
-Bob
I don't see how it is possible to have no sliding between a non-roller tip rocker and the valve stem. The angle between the two has to change as the valve moves. If the angle changes, there has to be a sliding motion, no? Maybe the area on the valve stem that this occurs on is very small, but metal sliding across metal still has to happen. Am I missing something?
paulie
paulie
Bob,
It appears that there is some kind of pad under that rocker wiper. Probably the reason being that the A-beam design of that rocker doesn't lend itself to a forked tip to support a roller, so they used a pad to avoid the weight increase of a forked tip. My conjecture, of course, but it would seem to have some basis considering that rocker construction.
In that scenario, it is very reasonable to skip the roller, in keeping with the selected rocker design. An H-beam rocker intended for a more streetable rpm range would be just as well suited with a less exotic and less expensive roller tip without mass concerns for the rpm range.
IMO.
IMO.
Tom,
What I could find on the steel version of those that TRD used is they reduce MOI by up to 90% and a 60% increase in stiffness. I’m not sure if they’re still used however.
Also, keep in mind that NASCAR engines keep the valve covers flooded with oil.
-Bob
Yes, understood.hoffman900 wrote: ↑Sat Dec 09, 2017 3:17 pm Tom,
My main point being that an item for a cost-no-object 11k rpm highly specialized application is not necessarily the best choice for a 6500 rpm cost sensitive hotrodder application.
Getting back to the roller rocker vs plain tip rockers, I had to make the decision for my application and I couldn't come up with any reason to not have the roller tips, so I got them. I still don't see any downside to having them in my application. If I needed 11k rpm, I would have designed an OHC head instead.
Of course. I think your set-up is awesome, btw. What application are those T&D, billet head rockers off of?twl wrote: ↑Sat Dec 09, 2017 3:43 pmYes, understood.hoffman900 wrote: ↑Sat Dec 09, 2017 3:17 pm Tom,
-Bob
The key is the shape of the rocker tip. When the arc is correct, the rocker tip will walk across the valve tip without skidding or scrubbing.A very smart older engine builder [ T.O.] turned me on to this. In the "bad old days" there were no roller rockers, and the stock rockers were often the weak link. He figured out how to make them work better than most others and accidently pointed me in the right direction.plovett wrote: ↑Sat Dec 09, 2017 2:43 pm I don't see how it is possible to have no sliding between a non-roller tip rocker and the valve stem. The angle between the two has to change as the valve moves. If the angle changes, there has to be a sliding motion, no? Maybe the area on the valve stem that this occurs on is very small, but metal sliding across metal still has to happen. Am I missing something?
paulie
Carlquist Competition Engines
Bob,hoffman900 wrote: ↑Sat Dec 09, 2017 3:58 pmOf course. I think your set-up is awesome, btw. What application are those T&D, billet head rockers off of?twl wrote: ↑Sat Dec 09, 2017 3:43 pmYes, understood.hoffman900 wrote: ↑Sat Dec 09, 2017 3:17 pm Tom,
They are BBC 1.8:1 ratio and they are modified with an angled adjuster to provide better angle of incidence with the angled pushrods . We do use the pushrod oiling with this head, which was absent in the stock block-style offset rockers with plain tips. Hydraulic roller tappets too. So far, no failures or issues reported up to 10k miles of the ones on the road. If we get 50k miles between rebuilds, we'll be happy. Time will tell.
hoffman900,
That Nascar style rocker you showed is a refinement of the type of rocker Chrysler used in 1956, with the intro of the Poly head. Shaft mounted, with a pad instead of a roller tip.
plovett,
Your thoughts & comments are 100% correct about the movement of the rocker tip across the valve. Both the angle of contact of the rocker tip with the valve tip, AND the distance between the rocker pivot [ trunnion or ball ] to the contact point on the valve tip change as the rocker opens & closes the valve. Result is some amount of sliding action of the rocker tip.
Who else has any experience building any max-effort race engines with rules mandated stock style rockers?
