Peak torque move puzzling?
Re: Peak torque move puzzling?
GTCA seeing this is a superstock engine is there any reason you don’t ask some the racer and engine builders over on the classracer sight.
I have talked with some over there and in person. Never got a definite answer so came here.
Cam events and intake tract length will move the peaks, but you didn't change either so not sure how the peak shifts happened?gtca9014 wrote: ↑Wed Dec 06, 2017 2:49 pmIt is a low compression 9:1 402 BBC with oval port, not peanut port heads. Cam is 288/284 and mid .800 lift although cam guy wants to try higher lift on next one. Should be 700hp if good. My old one goes thru at 82-8400 with peak power at 7300. would like peak hp at 77-7800 and cross at 87-8800.
What lobe seperation and where is the intake centerline?
Which intake manifold and are the runners extended?
I have seen headers with rust scale in them knock a surprising amount of power off a motor at times.
So your old motor when dynoed hit peak hp above 7800, with regular Oval ports?
111 in at 106LSP wrote: ↑Fri Dec 08, 2017 6:52 amCam events and intake tract length will move the peaks, but you didn't change either so not sure how the peak shifts happened?gtca9014 wrote: ↑Wed Dec 06, 2017 2:49 pmIt is a low compression 9:1 402 BBC with oval port, not peanut port heads. Cam is 288/284 and mid .800 lift although cam guy wants to try higher lift on next one. Should be 700hp if good. My old one goes thru at 82-8400 with peak power at 7300. would like peak hp at 77-7800 and cross at 87-8800.
Dart no extention of runners 1 1/8 QJet adapter/spacer
No, old motor 7300 with peak tq 6200. New motor cam was to move peak power to 76-7800 range.
How much Hg is the motor pulling at peak rev's?
You really need to test either with a dyno that can give you these numbers, or at the track.
- John Wallace
X2!
The BSFC looks wrong.
Using the corrected numbers it looks like the thermal efficiency is around 35% at peak HP?
(way too good?)
Need uncorrected HP/Tq numbers.
If that last column is vacuum, you are running a very small carb.
(but the numbers don't seem to be for that)
Are you using a thermal barrier on pistons/heads?
(way too good?)
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
I believe it has something to do with the start RPM difference of the two tests. One other thing to notice is the RPM this engine is run at....more converter more gear, faster car.
