Cryogenic Treatment
Re: Cryogenic Treatment
I cryo tested a piston for a Pro Mod customer, he was interested in longevity and we wanted to know if it changed dimensionally. Ring grooves in particular. He then ran that piston with the untreated pistons with no appreciable difference. He didn't order any more so we did not push that process while not discouraging those who swore by it. Mondello in particular wanted to treat everything in the motor.
From the reference point of absolute zero, cryogenic treatment is just 'heat treating' and I see no reason why all metals should respond the same..
Is it possible to do a back to back test and what test would you perform?
Given we are dealing with 'durability' (I think) I guess it's a tough one hence no-one seemingly done it.
Maybe something along the lines of changing up one front rotor, then when the first pair is used up, put a cryo part on the other side...
You need to do proper lab test for wear resistance, hardness, strength, fatigue etc and then look at the microstructure to see what is going on if anything. Field testing is a long way from being conclusive as it's always quite uncontrolled
My apology if this was answered in the previous posts... but does aluminum show any benefits from this treatment? The company that makes the rockers I use currently offers cryo as an upgrade for them, but I've never understood where the advantage for aluminum would be? Thanks - Brad
Haha...was think that too...impressive...Schurkey wrote: ↑Fri Dec 01, 2017 2:15 pmMother Of God! A 5-horse Briggs making 1000+ NA hp, and doing it for thirty-plus yearsfdicrasto wrote: ↑Fri Dec 01, 2017 9:53 amAn interesting story at the time involved 5 hp Briggs and Stratton engines fully assembled being cryoed and claims that when run and oil changed, little or no contamination in oil compared to non treated engines. As far as documenting improvements, I can only say that after 30+ years that block is still in one piece making 1000+ NA hp as of this spring.
If you put one treated rotor and one untreated on the front it would be quite a reasonable test. Wish i'd thought about it before as I've had a few done.
