Wondering if anyone know's what the OD is of the pin bushings they use? Honda pin size.
Anyways, what I'm looking at doing is removing the bushings and running them with .912 pins as a press fit.
Plausible?
Scat/Eagle .866 pin Bushings
Re: Scat/Eagle .866 pin Bushings
I don't know if there is a standard. I've replaced scat and eagle, and the eagle were thinner wall.
I think they're .945. Trend will make bushings for you at about 15.00 a piece.
Make sure you know what you want.
