Why? That is, what’s the theory for rotating collector firing order pattern? Not asking for proof, but simply what’s the logic.
My thinking is that you can get a shallower angle between two pipes if the are next to each other rather than across, given the areas you want to run. The shallower angle gives more “pull” and less turbulence.
