Leak testing with gas ports
I have run gapless rings for years. On my new engine I have 043 gas ported pistons. What leakage numbers should I expect on a 4.600 bore? Should the test be done at a high air pressure?
Re: Leak testing with gas ports
Gas ports won't affect your leakdown results. Perform the leakdown test the same way that you did it with the gapless rings.
Bill
SAE Member (30 years)
2-3% would be excellent with standard style(non-gapless) rings. You can run higher leak down percentages but why not shoot for low #'s
Your post is a bit ambiguous; it's not clear if your new rings are still Gapless®. If so, I used my Snap On gauge last week on a 5 year old (seats refreshed last winter) 380" 4.175" bore 700 HP @ 8,000 SBF racer with lateral gas-ported 1 mm Gapless® top rings. New it showed zero to 1%. It now measures mostly 1%, the worst 2%. Proportionally for a 4.6" bore, that would be 1.1 to 2.2%.
