088 BBC head flow data?
vic_dahn
Post by vic_dahn »
Does anyone have the STOCK head flow for the 088 BBC head? I am going to be working on some soon but I would like to know where I am going to start.
I have a flow bench but no heads yet so I would like to compare.
Thank you
Vic
Frankshaft
Re: 088 BBC head flow data?
Post by Frankshaft »
330ish intake, 200 ish ex.
mag2555
Post by mag2555 »
If I recall right without digging up my flow test sheets, the best stock intake on a 088 casting hit 325 cfm@ .700" lift, the Exh low topped out at 200 cfm@ .850" lift.
How much power are you needing to yank out of them?
Be sure to use a Bore adapter that is within .040" of what the real as run Bore will be!
