LS3 Carbed build
CGT
LS3 Carbed build
Post by CGT » Fri Nov 17, 2017 11:14 am
I have a complete LS3 core laying around. I've held on to it figuring there will be a point when my supercharged LS3 Camaro's stock shortblock will give up on me.
I have a friend that runs a carbed(methanol) LS in his bracket car. His motor is tired, and he wants to replace it or fix it. I'm thinking about building an engine for him with this core(or to keep as a dyno mule) :D What do you guys think it could make? I want to use as many factory parts as possible(crank, rods, valves, rockers etc.) Any ideas or guesses?
4.070 x 3.622
14:1 Compression
Hydraulic Roller (under .700 lift)
LS3 heads
Super Victor Intake
"If you pick up a starving dog and make him prosperous, He will not bite you. This is the principal difference between a dog and a man"
Frankshaft
Re: LS3 Carbed build
Post by Frankshaft » Fri Nov 17, 2017 12:50 pm
4.070 x 3.622
14:1 Compression
LS3 heads
Super Victor Intake
700+
CGT
Post by CGT » Fri Nov 17, 2017 1:09 pm
4.070 x 3.622
14:1 Compression
LS3 heads
Super Victor Intake
700+
Really? I was thinking quite a bit less than that.
Frankshaft
Post by Frankshaft » Fri Nov 17, 2017 1:14 pm
I guess it all depends. But it is possible. 650 real easy.
CGT
Post by CGT » Fri Nov 17, 2017 1:37 pm
Yeah i was kinda thinking 650. But I honestly dont know what to expect. Any tips or ideas on anything Frankshaft? Valve events, porting, valve job?
Thanks
autogear
Post by autogear » Fri Nov 17, 2017 2:08 pm
Fill out a cam request for Jones Cams?
CGT
Post by CGT » Sat Nov 18, 2017 9:44 am
No more biters?
Frankshaft
Post by Frankshaft » Sat Nov 18, 2017 9:48 am
They respond to less intake duration, big spreads on ex, and WIDE lobe seps. like out to 118. Being a carb and 14:1 on methanol, could throw a monkey wrench in that, never ran one with that combo.
CGT
Post by CGT » Sat Nov 18, 2017 10:36 am
Thanks. I'm looking at COMP CAMS LOBE#13065 Intake #3447 Exhaust on 111 or 112 currently. Have you messed with the heads much?
randy331
Post by randy331 » Sat Nov 18, 2017 1:28 pm
What do the LS engine builders think of the GM 88958675 intake for LS ?
Or what other one should I look at ?
Got 6.0 that I'm doing that will get a single plane and carb.
4.030 bore" x 4" stroke, 10.5-1 comp- ported 243 casting heads, 243-258 @ .050" Comp Hyd roller. Mahle flat tops with 1mm 1mm 2mm rings.
How much power should I expect from this one ?
Hope * don't mind me posting this LS on here too ?? :D
CGT
Post by CGT » Sat Nov 18, 2017 3:07 pm
Id guess 625hp and 560 torque on yours but who knows.
I believe the 88958675 is the same as Edelbrock 28097. But I can find any published information on sizes for any of the LS carbed intakes.
I dont know if i should do the Victor Jr or Super Victor on mine, 4150 or 4500. Anyone know anything about any of these manifolds?
CGT
Post by CGT » Sun Nov 19, 2017 9:35 am
Would it be worth offset doweling the cylinder head over?
A_VAS
Post by A_VAS » Sun Nov 19, 2017 3:38 pm
what bore you sitting on there? 4.070 ?
CGT
Post by CGT » Sun Nov 19, 2017 4:08 pm
Thats 4.005 pictured. I will be using a 4.070.
JodyB
Post by JodyB » Sun Nov 19, 2017 4:21 pm
Dual 4 hi-ram:)
