Vortec 350 build
rocketracer380
Vortec 350 build
Post by rocketracer380 »
Here's my set up std bore 99 block stock lt1 crank rods and pistons eqch350c heads with 2.02 1.60 valves very minor diy porting milled to 58 cc .010 decked block about 10.5:1 elimnator gm intake 750 Holley and crane solid cam I've seen similar builds anyware from 375 to 460 +with hr cam and air gap intakes im hoping for 450 plus any one have experience with a similar build 350 please chime in thanks by the way I have very little cash in this build mostly parts around the shop.
FC-Pilot
Re: Vortec 350 build
Post by FC-Pilot »
I am not sure just what you are looking for but I have a similar build. It is a 358" with SRP professional piston and ring kit with EQ heads I ported myself and a HR cam from Chris Straub. A Chinese single plane intake I ported myself and a carb I pieced together myself. It made 482HP at 6,600 RPM's on pump gas. My compression was a touch lower being right at 10 to 1.
Paul
rfoll
Post by rfoll »
If you use an aftermarket head, It's not a Vortec build, the heads are not the same, likely significantly better.
rocketracer380
482 nice numbers how was the torque where was your quench
FC-Pilot
Post by FC-Pilot »
rocketracer380 wrote: Mon Nov 13, 2017 6:10 pm 482 nice numbers how was the torque where was your quench
I don't remember where the torque peaked and how high. I will have to pull it back up on the computer when ever I get back to the shop. I always like to set my squish between .035 and .045. I think that engine was closer to .040 being it went into the family play boat. Being in a boat I was not overly concerned with low RPM grunt as we used gear and prop to get it where it was happy. We still have a touch of boat setup to dial in, but the engine is happy and more than willing.
cjperformance
Post by cjperformance »
FC-Pilot wrote: Tue Nov 14, 2017 12:35 pm
Thats more like a chevy powered lawn chair than a boat!!
OP, what solid cam/spec do you have there?
