Viton or Silicone rear main seals SBC
RT Machine
Post by RT Machine » Mon Nov 13, 2017 5:44 am
Is there any real difference in sealing ability and longevity between Viton or Silicone [2 piece] type rear seals in a performance application ?
Viton has a higher heat rating and twice the price, but are they better ?
Sparksalot
Re: Viton or Silicone rear main seals SBC
Post by Sparksalot » Mon Nov 13, 2017 6:17 am
Yes, Viton is far superior in that application.
engineguyBill
Post by engineguyBill » Mon Nov 13, 2017 12:41 pm
I have always used silicon rear main seals, with excellent results. Available from many sources, but all are probably manufactured by Fel-Pro.
Bill
SAE Member (25+ years)
ASE Master Certified Engine Machinist
- Theodore Roosevelt
A_VAS
Post by A_VAS » Wed Nov 15, 2017 5:38 pm
Viton will not swell or change properties much in the presence of hot engine oils
viton has better low temperature performance, down to like -40*C.
it is far superior to silicone in those 2 areas.
raw material is about 15x the price of a regular VMQ silicone
