Yes I have seen the house one, I think 3D printers are cool but it wouldn't be for me, I still use my phone for phone calls and a map to figure out where I am going.Dave Koehler wrote: ↑Wed Nov 15, 2017 7:51 amWhat do you mean in the house Willis? It could be the house!GARY C wrote: ↑Wed Nov 15, 2017 12:04 am 3D printed meat: It's what's for dinner.
https://www.cnet.com/news/3d-printed-me ... or-dinner/
It probably wont be long before every house has a small 3d printer along with their pc and inkjet.
https://www.youtube.com/watch?v=SObzNdyRTBs
This little thing looks like an inexpensive way to get your feet wet.
https://www.monoprice.com/product?p_id=21711
Video of same
https://www.youtube.com/watch?v=ispolAHB4jA
Reality Check
https://www.youtube.com/watch?v=wLJhfhrVK2U
3 -D printing
Re: 3 -D printing
- Dave Koehler
Re: 3 -D printing
Tell us of your experience with cheap and which units did you try?
Re: 3 -D printing
I have not had a good experience with acrylic frame printers. I just could not get the frame squared-up in all axes.Dave Koehler wrote: ↑Wed Nov 15, 2017 3:10 pmTell us of your experience with cheap and which units did you try?
Rumor has it that the Creality CR10 is a great starter printer. When they first appeared you could get one for about $350.
3D printing is like cooking. You can have the best hardware, software. But it takes a lot of experience to get everything else right.
Re: 3 -D printing
Maybe but I doubt it would be practical.GARY C wrote: ↑Wed Nov 15, 2017 12:17 amAre you able to do them transparent enough to see fuel distribution? I recall seeing one done a few years back that was made in 2 parts and then bolted together for easy porting and modifying and it was simi transparent.SchmidtMotorWorks wrote: ↑Wed Nov 15, 2017 12:08 am I have printed 3 complex intake manifolds in the past 2 months.
It takes about a week to print one V8 manifold with a good printer and it is expensive.
A manifold is good for about 20 dyno pulls and it takes a lot of prep to get one sealed enough to run.
I am putting together a single cylinder engine and dyno now with a TFX pressure measurement system so that I can make single runners on the CNC in urethane instead of printing.
After this last set of manifolds, I say the time and money spent would have been better invested in CFD simulation effort and single cylinder engines before anything V8.
Dyno testing just doesn't return enough information to make decisions with.
Re: 3 -D printing
had a mate that used to do ABS basically 'toys' that had less than ideal infill so cracked after a while, i now use a professional place (machine probably costs 200x the cost) and get either Nylon12 or Alumide. the stuff is actually usable if temps are reasonable but if generating huge clamp load under bolts then gotta spread load to avoid creep/relaxation. it costs more than mates rates but its not too bad if you shop around and you know how the price is calculated you can design around that sometimesDave Koehler wrote: ↑Wed Nov 15, 2017 3:10 pmTell us of your experience with cheap and which units did you try?
Re: 3 -D printing
with a manifold design (with distribution issues etc) how much is a single cylinder representation gonna tell you that a 1D sim wont?SchmidtMotorWorks wrote: ↑Wed Nov 15, 2017 3:54 pmMaybe but I doubt it would be practical.GARY C wrote: ↑Wed Nov 15, 2017 12:17 amAre you able to do them transparent enough to see fuel distribution? I recall seeing one done a few years back that was made in 2 parts and then bolted together for easy porting and modifying and it was simi transparent.SchmidtMotorWorks wrote: ↑Wed Nov 15, 2017 12:08 am I have printed 3 complex intake manifolds in the past 2 months.
Re: 3 -D printing
Just to chip in my own two cents, one thing you can do with even a 3d printer that only handles the basic plastics is use it for investment casting patterns.
... of course, then this gets into a topic about home foundry stuff and not just home 3d printer stuff.
- jmarkaudio
Re: 3 -D printing
No, I used a pump cam in a scanner to get the basic starting shape. I then sketched a vector image over it in Illustrator, making mods where I wanted to. Then imported the dxf file into Fusion 360, extruded the pieces from there.statsystems wrote: ↑Tue Nov 14, 2017 11:31 pmAre you making custom pump cams or just copying Holley stuff?jmarkaudio wrote: ↑Tue Nov 14, 2017 9:20 am I've done some small carb parts, pump cams and vent whistles.
Couple others I drew by hand.
Mark Whitener
www.racingfuelsystems.com
____
____
Re: 3 -D printing
It depends on what you mean by distribution issues.
The engine I am working on now is fuel injected after 0.01 seconds of open throttle, distribution has not been a significant issue.
Having completed the last series of manifolds dyno tested them, modified them and dyno tested again through 2-3 more cycles of experiments, I end up with recipes but not understanding of exactly why some features caused the changes they did.
Given the cost and time of that process, I will put much more effort in 1D and 3D simulation on the next series of experiments to have a better understanding of why things work the way they do.
The way I see things now; there is substantial opportunity to optimize runner design with non-linear cross-section designs.
My current list of variables is about 8, on a V8, that is just impractical to prototype and test. At the rate I am going that would get into the $ hundreds of thousands and the project would not have positive ROI at that price no matter what is discovered.
Re: 3 -D printing
i was thinking you had common plenum similar to single plane manifoldSchmidtMotorWorks wrote: ↑Fri Nov 17, 2017 11:40 amIt depends on what you mean by distribution issues.
i'm using 3D printing to do some IR runners where packaging constraints are problematic and i need a slight curve shape similar to the S54 engine. 3D printing is bar far the cheapest way i know of doing a small batch of 6 when you value you own time (ive hand glassed then before but takes ages). i did some crude CFD in fluent to get flow trajectories about as uniform as possible at the outlet. i can input the size at various positions along the length in engmod4t but the slight curve isn't captured
Re: 3 -D printing
They are forward facing throttle body manifolds for the Coyote engine.digger wrote: ↑Fri Nov 17, 2017 4:50 pm i was thinking you had common plenum similar to single plane manifold
