Anyone use Motul 10w40 break-in oil?
BradH
Post by BradH » Sun Oct 15, 2017 11:01 am
I can get it locally and am wondering if it might be a better choice than the Brad Penn 30 wt break-in oil on my shelf, considering it's a solid roller with 600# open spring loads.
swampbuggy
Re: Anyone use Motul 10w40 break-in oil?
Post by swampbuggy » Sun Oct 15, 2017 11:26 am
Solid roller................start with what your gonna use, as soon as you get oil pressue and wait a bout 30 seconds put some load on it and vary up and down to face in rings if on dyno. If in car accelerate ad de-celerate in low gear for about 2 mins. Mark.
statsystems
Post by statsystems » Sun Oct 15, 2017 2:21 pm
Either one will work. I'm not sure how the Motul is formulated but what little I've used of Motul has been good.
DaveMcLain
Post by DaveMcLain » Sun Oct 15, 2017 4:49 pm
I don't really think that you need any sort of special break in oil when you're running a roller cam.
ZEOHSIX
Post by ZEOHSIX » Sun Oct 15, 2017 5:33 pm
Break in oils can make a HUGE difference on piston ring break in/leak down from what I have observed. I use Driven BR30 myself.
statsystems
Post by statsystems » Sun Oct 15, 2017 5:52 pm
Yes break in oils do make a big difference.
racear2865
Post by racear2865 » Sun Oct 15, 2017 6:04 pm
what you start your engine on does make a difference. Break in oil does help the rings seat but also helps the roller bearings burnish in. I start on 10 x 40 BR Gibbs. Just pick a good break in oil and go. If you want more info, read intervue with Lake Speed Jr
reed
roc
Post by roc » Mon Oct 16, 2017 1:04 pm
Very interesting, those are strong endorsements. I never took break-in oil seriously (aside the ZZDP for flat tappets), but I've never done any in depth study.
DaveMcLain
Post by DaveMcLain » Mon Oct 16, 2017 4:54 pm
This sort of thing is difficult to study but I've tried. I have not had trouble with engines broken in using either a "break in" or a regular oil when the engine has a roller cam. As long as the cylinders are finished properly for the rings I'm not terribly convinced that its any big deal.
exhaustgases
Post by exhaustgases » Mon Oct 16, 2017 5:15 pm
So I'm wondering, what brand and viscosity did Chevrolet break in the old 265's and 283's on back in 1955 to 1957? Lots and lots of flat tappets in those days.
GARY C
Post by GARY C » Mon Oct 16, 2017 5:18 pm
reed
Would he be the best source of info considering he has a vested interest in the product?
We always ran the cheapest non detergent oil available with no issue and added GM EOS if it was flt tappet.
roc
Post by roc » Mon Oct 16, 2017 6:05 pm
That's my thinking too. But I also believe break-in oils won't fix improperly finished bores.
roc
Post by roc » Mon Oct 16, 2017 6:11 pm
With the very small exceptions aside, all SBC's before 1987 were flat tappets.
BradH
Post by BradH » Tue Oct 17, 2017 7:05 am
I'll throw in the observation that a bunch of VOAs on various brands of break-in oils revealed that everybody seems to blend them differently, including HUGE variations in the amounts of comon anti-wear & detergent components. I don't know which brand(s) got it right and which ones are totally off in left field.
I
BradH
I
