What seats for Ti valves?
Krooser
Post by Krooser » Sat Oct 14, 2017 9:18 pm
Got my used Ti valves yesterday... shipped in a Del West box... the instructions on the box say use a beryllium copper seat or another softer deal... what say you?
PackardV8
Re: What seats for Ti valves?
Post by PackardV8 » Sat Oct 14, 2017 9:34 pm
Most BeCu seats are huge. They're only practical in the race heads which have the extra aluminum in there to accept them. Maybe there exists a smaller diameter, smaller depth version, but those I've seen would be too large for the heads I would be using.
I was then told, "Are you going to be running 500 miles at 9,000 RPMs? That's where the BeCu seats are required. Your application doesn't need them. Just run on iron seats."
Krooser
Post by Krooser » Sat Oct 14, 2017 10:40 pm
Personally I couldn't run 5 miles @ 9 rpm's.... :D
Thanks Jack....
englertracing
Post by englertracing » Sat Oct 14, 2017 10:40 pm
The copper seats are more for the exhaust side as the ti is lousy at transferring heat to the guides and seat, the copper sucks the heat out.
On uncoated ti valves they may reduce wear.
You can call performance alloy and have them make you some moldstar 90 exhaust seats.
It's a copper beryllium replacement that is supposed to be superior.
user-9274568
Post by user-9274568 » Sat Oct 14, 2017 10:42 pm
Dura-Bond Killer B's and a CrN coated valve.
ZEOHSIX
Post by ZEOHSIX » Sun Oct 15, 2017 5:41 pm
The GM LS7/9 used powdered metal seats with their coated Ti Del West valves. Cu Berylium is very hazardous and breathing or getting chips into your body can really mess you up.
statsystems
Post by statsystems » Sun Oct 15, 2017 5:51 pm
I stopped using BC seats and started using nickel bronze IIRC. If I think of the name of the company I bought them from ill post it. The NB seats machined better and didn't produce the hazardous things that BC does.
Just thought of it.
Kibblewhite machine or something like that. It's defiantly Kibblewhite.
Krooser
Post by Krooser » Sun Oct 15, 2017 9:24 pm
Great replies... thanks gentlemen.
engineguyBill
Post by engineguyBill » Mon Oct 16, 2017 11:26 pm
What say me? Me say that if the supplier recommends that you install Beryllium Copper seats, than you do that. OR call them and inquire about using alternative materials. Much more reliable than asking a bunch of us doofaces on the internet . . . . . . .
Bill
SAE Member (28+ years)
- Theodore Roosevelt
Krooser
Post by Krooser » Tue Oct 17, 2017 12:22 am
Nodular iron, bronze or CuB or another softer metal... at least that's what Del West sez...
sbcharlie
Post by sbcharlie » Tue Oct 17, 2017 7:52 am
use mold star 90 is the only way to go sbc
englertracing
Post by englertracing » Tue Oct 17, 2017 6:02 pm
Pretty sure Del west sells the ms90 seats
Performance alloy makes the ms90, for injection molding applications, but they actually have a valve seat department, they will make the seats to your specs.
Krooser
Post by Krooser » Tue Oct 17, 2017 8:40 pm
user-9274568
Post by user-9274568 » Tue Oct 17, 2017 8:44 pm
Done!
Krooser
Post by Krooser » Tue Oct 17, 2017 11:05 pm
Thanks *...
