Page 3 of 5
Re: Broken rod bolt
Posted: Fri Oct 06, 2017 4:27 am
by Geoff2
Digger,
No not one big bearing. Each has it's own oil supply; & same oil pressure. So the oil trying to exit the trapped rod is stopped/slowed down by the oil from the 'free' rod.
Re: Broken rod bolt
Posted: Fri Oct 06, 2017 6:56 am
by tuffxf
Gday
What engine, what crank, what cylinder?
Sorry to see carnage!
Cheers
Paul
Re: Broken rod bolt
Posted: Sat Oct 07, 2017 11:30 pm
by 340king
The photo clearly shows a fatigue break. That's the easy part. Now why there was a fatigue break is the real question.
1. A rod bearing failure could have caused excess loading, but it typically still takes quite a few cycles to get the rod bolt to break when the loading is above the knee. (The knee is the point on the fatigue failure cycles chart where the number of cycles becomes irrelevant as the member is strong enough to survive forever at that cyclical loading level.)
2. The rod bolt had a flaw that allowed a stress riser and started a fatigue crack. The crack started at the outer most edge of the bolt probably in the neck down area. My best guess is that the machining process wasn't smoothed up enough with the surface finishing process.
3. The rod bolt wasn't torqued high enough to maintain the clamp loading of the assembly. This allowed cyclical loading to impact the bolt.
My best guess is that numbers 2 and 3 are to blame either separately or combined.
Did you have stretch measurements on the bolts at rebuild?
Re: Broken rod bolt
Posted: Sun Oct 08, 2017 7:53 am
by MELWAY
The rod and bearing are burnt black from loss of hydrodynamic oil wedge. End of story
Re: Broken rod bolt
Posted: Thu Oct 12, 2017 6:18 pm
by 1972ho
Now if the rod bearing was starved for oil wouldn’t both of them have failed.Just asking
Re: Broken rod bolt
Posted: Thu Oct 12, 2017 6:27 pm
by tuffxf
Gday,
Vey common on some engines to fail just one rod bearing of a pair from lack of oil or an oil system issue.
What type of engine and what number is the failed cylinder ?
Cheers
Re: Broken rod bolt
Posted: Thu Oct 12, 2017 7:39 pm
by 1972ho
#7 rod on 351cleveland
Re: Broken rod bolt
Posted: Thu Oct 12, 2017 8:15 pm
by user-23911
1972ho wrote: ↑Thu Oct 12, 2017 6:18 pm
No , of course not.
They're fed from different main bearings.
Re: Broken rod bolt
Posted: Thu Oct 12, 2017 8:21 pm
by tuffxf
2, 3 and 4 mains on a cleveland feed two rods each.
Cheers
Re: Broken rod bolt
Posted: Thu Oct 12, 2017 8:43 pm
by 1972ho
Any chance this crank rod journal can be repaired and can you see a way to get the #3 rod bolt to loosen.
Re: Broken rod bolt
Posted: Thu Oct 12, 2017 10:21 pm
by user-23911
In the case of a Cleveland......numbered 1234 down one side and 5678 down the other
Then no 7 (spun )pairs with no 3 on the same throw.
No 3 big end feeds from no 3 main and no 7 big end feeds from no 4 main.
If there's going to be a problem with another bearing due to the main not feeding properly then it will be no 4 big end as that also gets oil from no 4 main.
Still separate oil feeds though.
Re: Broken rod bolt
Posted: Thu Oct 12, 2017 11:46 pm
by 1972ho
Anybody know if a windage tray can have a effect on the oil system,the reason I ask this is that is the only change that I made to this engine in the many years that I have ran it.I know one thing I will more than likely not install it on the rebuild.
Re: Broken rod bolt
Posted: Fri Oct 13, 2017 12:23 am
by tuffxf
Gday ,
As i aked earlier, is it a standard ford crank?
Cheers
Re: Broken rod bolt
Posted: Fri Oct 13, 2017 9:48 am
by 1972ho
Tuffxf yes 4MA cleveland crank 3.513 stroked.
Re: Broken rod bolt
Posted: Fri Oct 13, 2017 11:18 am
by tuffxf
Gday,
Yeah ok are you also using half grooved main bearings?
How is the bottom end set up clearance and oiling system wise ?
Flatty or roller?
Lifter bushes?
What type of lifters?
Cheers
