tuning with afr meter
Re: tuning with afr meter
If you have already tuned and jetted for maximum MPH and you're not damaging anything then your afr is where it should be. When you tuned jetting you set that necessary afr for top mph. Changing the jetting based on an afr number now will not help anything.
what is your AFR after tuning
Smokey
Smokey
