***Post Pics of what you are working on**
FC-Pilot
Re: ***Post Pics of what you are working on**
Post by FC-Pilot » Tue Dec 05, 2017 12:34 pm
Zmechanic wrote:
Tue Dec 05, 2017 10:58 am
Alright, here's a new one. This one actually pays the bills. Making sure a product line I'm working on doesn't violate the "this device may not cause harmful interference" statement you see on things. Although this is an industrial device so the levels and frequencies aren't the exact same.
10M radiated emissions in anechoic chamber. It's dead quiet in there and ZERO cell signal.
That is pretty cool. I have traveled up to Michigan to work in some wind and temp chambers, but never a sound chamber like that. That is pretty cool. My brother and I built a recording studio in his home and it looks like a MUCH smaller version of that. Cool to see.
Paul
Newold1
Post by Newold1 » Tue Dec 05, 2017 8:28 pm
Is that what they call an "Anechoic Chamber" ? That could probably swallow the noise of a 600 inch BBC with open headers EH!
Who cuts all those foam shapes?
Zmechanic
Post by Zmechanic » Tue Dec 05, 2017 10:44 pm
Yes, it's usually called an anechoic chamber. This one in particular is for electromagnetic waves instead of acoustic, but the guiding principle is very similar so it does absorb sound very well too. The foam is impregnated with carbon to make it electrically lossy, though.
The antenna in the picture picks up all the electromagnetic radiation coming off the test device to make sure it's within limits.
ptuomov
Post by ptuomov » Sun Dec 10, 2017 8:57 pm
John’s working on fixtures to make more twin turbo pipes:
swampbuggy
Post by swampbuggy » Mon Dec 11, 2017 8:04 pm
What engine we got there PT ?
ptuomov
Post by ptuomov » Tue Dec 12, 2017 12:43 pm
It's a Porsche 928 S4 engine. Take a look at John Kuhn's youtube channel: https://www.youtube.com/watch?v=cxn-LxwsrnU
hoodeng
Post by hoodeng » Sat Dec 16, 2017 10:39 pm
Started 9.30 this morning ,finished 2pm .heads, bores and crank true done yesterday. Best thing was Booker T and the MG's ,'Time is tight ' was just playing on the wireless!!
Cheers.
bentvalves
Post by bentvalves » Sun Dec 17, 2017 5:30 pm
David Vizard wrote:
Mon Oct 23, 2017 6:51 pm
The op to be shown next will be the intake port matched to the heads.I find it is an easier job when no pistons are in the block as you can put light up the bores. I am not using these AFR 227 heads on this engine But the ports are in the same location as the heads being used.
BTW have had some really good results with these AFR 227 CNC headsa right out of the box.
The last set made over 1.42 ft/lbs per cube on an 87 octane fuel build. This was while Tony Mammo was still at AFR. Tony's comment 'How Much? Holy S**t'
DV
what are the valve guide looking pieces in the valley?
Keith Morganstein
Post by Keith Morganstein » Sun Dec 17, 2017 5:50 pm
Square decking an LS
