Travel limiting Hydraulic Roller lifters
Has anyone on here made spacers to travel limit a Morel Retrofit Hydraulic lifter .842 sbc?
Re: Travel limiting Hydraulic Roller lifters
The way the lifter is assembled I don't know how you would take them apart.CGT wrote:Has anyone on here made spacers to travel limit a Morel Retrofit Hydraulic lifter .842 sbc?
True, I hadn't really considered that.DaveMcLain wrote:The way the lifter is assembled I don't know how you would take them apart.CGT wrote:Has anyone on here made spacers to travel limit a Morel Retrofit Hydraulic lifter .842 sbc?
You simply remove just the spring and machine spacers to depress the piston almost fully and re-insert the spring.DaveMcLain wrote:The way the lifter is assembled I don't know how you would take them apart.CGT wrote:Has anyone on here made spacers to travel limit a Morel Retrofit Hydraulic lifter .842 sbc?
[quote="Walter R. Malik"]
Double post ... sorry
Yes but how do you do that with the Morel lifter where the insides won't fit past the swedged end of the pin that holds the pair of lifters together?Walter R. Malik wrote:You simply remove just the spring and machine spacers to depress the piston almost fully and re-insert the spring.DaveMcLain wrote:The way the lifter is assembled I don't know how you would take them apart.CGT wrote:Has anyone on here made spacers to travel limit a Morel Retrofit Hydraulic lifter .842 sbc?
Yeah Im familiar with what it take to travel limit them with spacers, was just inquiring if anyone has or does spacers for this particular lifter. I've had quite a few O.E lifters apart, but wasn't aware of what obstacles may be involved with these.
Yes, Morel has. They call them "part#4789"CGT wrote:Has anyone on here made spacers to travel limit a Morel Retrofit Hydraulic lifter .842 sbc?
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Wow. Thanks alot . Those are expensive spacersCamKing wrote:Yes, Morel has. They call them "part#4789"CGT wrote:Has anyone on here made spacers to travel limit a Morel Retrofit Hydraulic lifter .842 sbc?
You are only taking the clip out and inserting about a .150" spacer to depress all the insides and reinserting the clip.DaveMcLain wrote:Yes but how do you do that with the Morel lifter where the insides won't fit past the swedged end of the pin that holds the pair of lifters together?Walter R. Malik wrote:You simply remove just the spring and machine spacers to depress the piston almost fully and re-insert the spring.DaveMcLain wrote:
I have done this myself several times.
NOW, the pushrod will also need to be longer.
Yes, but they come with a free set of lifters.CGT wrote: Those are expensive spacers
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Can the spacer go under the plunger so you don't need to modify the pushrod length?
But you can't get the plunger past the rivet that holds the tie bar.
Jim
I'm asking about a factory style lifter...no tie bar to worry about.
