Which Is Faster - 600hp@6200 or 600hp@7100
Re: Which Is Faster
Which one is faster depends. Top fuel cars are max 8.250rpm or so. 8000horse? Does that make them slower than a 10.000rpm 8000hp car?
How long is a rope?
How long is a rope?
Re: Which Is Faster
Back to which is faster, unless you are severely limited by gearing options, as in DV's example, rpm wins EVERY TIME!
Before the gear rule, we would sometimes sacrifice power to be able to turn more rpm.
Re: Which Is Faster
That was the first article I ever read, I was building an almost identical for a 79 T/A when I found the 2 part story in a shop I worked at.
- psychomotors
Re: Which Is Faster
Gary , I'm going to assume this was in Popular Hot Rodding?
Re: Which Is Faster
Yes!psychomotors wrote: ↑Fri Oct 20, 2017 10:57 am Gary , I'm going to assume this was in Popular Hot Rodding?
- psychomotors
Re: Which Is Faster
Thanks.GARY C wrote: ↑Fri Oct 20, 2017 11:03 amYes!psychomotors wrote: ↑Fri Oct 20, 2017 10:57 am Gary , I'm going to assume this was in Popular Hot Rodding?
Re: Which Is Faster
Ah; there's a formula for that: let 'A' be one end of the rope and 'B' its mid-point. The length then will be 2AB.
Q.E.D.
Re: Which Is Faster
In answer to the question,
If we convert the motor that spins at 7,100 back to 6,200 you get a torque number of 689 Nm for both motors. If you convert the 6,200 torque number to 7,100 you get both motors generating a torque number of 601 Nm. So no surprise there.
The speed down the drag strip is all about the amount of torque being applied to the wheels at a given speed. So based on my calc's that amount of torque will be exactly the same. As mentioned before there maybe some gains in the lower friction number but that's the limit of the difference.
Tony
PS
Hi DV I am the guy you meet in Sydney with the new intake design.
Tony
PS
Re: Which Is Faster
I have a question Tony:
Would you run a engine that the peak HP occurs @ 5800 RPM, and turn it 7000 RPM through the lights in a drag race situation?
Re: Which Is Faster
Here's an interesting example using some data from a two barrel circle track engine which was making 486 horsepower at its peak at 6200rpm. At 7100 it was making 462 horsepower and at 5200rpm it was also making 462 horsepower. At the track the car is geared to turn about 7200rpm. I know what it would run like if it was only turning 5200rpm, it wouldn't be good. In an ultimate speed test though would the car go the fastest if it were geared to turn 5200, 6200 or 7200rpm?
Re: Which Is Faster
RPM is wheel speed, pretty simple.
Re: Which Is Faster
so more rpm is ultimately better even if the car doesn't make power there? i've seen a car pick up going from 4.88s to 4.10s in the 1/4 and that motor probably peaked around 5800-6000 10.1 390 with a 230-236@.050 hydraulic flat tappet with around .550 lift a torker and 850 holley. picked up 3 tenths with the gear change same tire and the difference in trap was 7100 with 4.88s and 6200 with 4.10s given power probably took a pretty big dive above 6000
Re: Which Is Faster
Most people would say that an engine that makes hp at a higher rpm requires more gearing to run optimally. But, I would say that the same higher rpm engine also allows you to run more gearing. Think about it.
It's a win for the high rpm engine, in my opinion. Obviously, there are drawbacks to running higher rpm, but speed is not one of them.
JMO,
paulie
JMO,
paulie
Re: Which Is Faster
You are talking about optimizing the gearing for a given combination. In your example 4.88's were too much gear for the engine. If the engine could make the same power at higher rpm, then maybe it could utilize more gear.AMXstocker1 wrote: ↑Fri Oct 20, 2017 4:17 pm so more rpm is ultimately better even if the car doesn't make power there? i've seen a car pick up going from 4.88s to 4.10s in the 1/4 and that motor probably peaked around 5800-6000 10.1 390 with a 230-236@.050 hydraulic flat tappet with around .550 lift a torker and 850 holley. picked up 3 tenths with the gear change same tire and the difference in trap was 7100 with 4.88s and 6200 with 4.10s given power probably took a pretty big dive above 6000
Re: Which Is Faster
Nobody has yet said how they'd build the 2 engines to make the quoted numbers .
As I said a few pages back, the one that makes the power at lower revs has boost.
The one that makes the same power at higher revs has a hot cam.
Boost always wins.
Boost always wins.
