Heat wrap and erosion
BOOT
Re: Heat wrap and erosion
Post by BOOT »
BOOT wrote:I'm not trying to find another way to heat shield objects from burning/cooking, letting hot air escape defeats the point of heat shielding if your trying to reduce underhood temps.
Correctly means follow the directions and don't overwrap to speed up the erosion, not corrosion that so many think is the result. The trapped heat erodes the metal from the inside until it becomes so weak it crumbles. I want to try n control the effect for limited concentrated erosion then take the wrap off. THEN I'll have the manifold ceramic coated inside & out.
j-c-c
Post by j-c-c »
You have lost me, but in my world, any wrap is "overwrap", and it's not possible to "wrap correctly", which is what I was trying to see if you had a holy grail answer, not yet it appears, from my vantage point.
BOOT
Post by BOOT »
j-c-c wrote: in my world, any wrap is "overwrap", and it's not possible to "wrap correctly",
You have YOUR answer and I'm not gonna waste time arguing with you about why you don't like or think wrap is worth it. I've stated my purpose of this thread clearly as I can.
user-23911
Post by user-23911 »
Subarus.......the EJ20 WRX etc.
They have sheet metal shields all along the exhaust.
The last one I played with, it had white powder inside, that's between the shield and the pipe.
Looks just like asbestos......maybe it IS. Not good for breathing?......not even a warning in the manual.
JDM of course......but what about the US specced ones?
Heat wrap from the factory?
Don't be silly.
That'll solve all the problems, just use asbestos like in the good old days.
BOOT wrote: Anyways since I recently ported a set of cast iron manifolds it occurred to me that I may want to OVER wrap the parts I can't get to n let it maybe port itself.
Thoughts?
It's going to port it's self?
It'll crack before that happens.
peejay
Post by peejay »
Air is a pretty good insulator. Heat shields are best.
I've never seen a wrapped header or exhaust that didn't look like garbage in short order from corrosion.
BOOT
Post by BOOT »
Cracking is possible I'd think but I've never wrapped cast iron manifolds and hope to have someone who has actually used the stuff comment.
