gear oil for ford rear
chevy art
Post by chevy art » Fri Sep 08, 2017 1:08 pm
what brand and weight gear oil should be used in my fore 9 inch true trac rear. car is street driven thanks art
mag2555
Re: gear oil for ford rear
Post by mag2555 » Fri Sep 08, 2017 1:42 pm
How about a 80w90 GL5 rated lube with a bottle of limited slip additive.
77cruiser
Post by 77cruiser » Fri Sep 08, 2017 1:45 pm
True Trac doesn't have clutches does it?
Jim
ProPower engines
Post by ProPower engines » Fri Sep 08, 2017 1:59 pm
I would suggest Redline full syn. light weight shock proof gear oil in the blue and white bottle.
The torque sensing differentials really like the full syn. oils and if you do beat on it it has the shear strength needed for hard working race applications
RCJ
Post by RCJ » Fri Sep 08, 2017 3:17 pm
If you have a lot of power or really deep gears (5.13,5.83 etc..) you will get less wear with 140wieght
ProPower engines
Post by ProPower engines » Fri Sep 08, 2017 3:23 pm
RCJ wrote:If you have a lot of power or really deep gears (5.13,5.83 etc..) you will get less wear with 140wieght
X2
If thats the case with a steep gear use the Red-Line 85/140 shock proof red
treyrags
Post by treyrags » Fri Sep 08, 2017 3:30 pm
Amsoil 75/90. Put it in and forget it.
