Glass Packs as Resonators
Belgian1979
Re: Glass Packs as Resonators
Post by Belgian1979 » Fri Sep 01, 2017 10:50 am
digger wrote:
Belgian1979 wrote:
digger wrote:Most of the glass packs I've used are perforated tube so not directional. They do work well when you get some length and volume.
Agreed. But it depends on what you want to have in terms of sound. Smaller volume attenuates at lower speeds but gives off brutal sound at higher engine speeds.
i ran two short hot dog cylindrical resonators in parallel part way down the exhaust on a twin exhaust system and it was terribly droney at low rpm.
So i designed a bigger volume one basically joined them like an oval twin in and out straight through muffler and it was significantly better. due to space restrictions the length had to remain about the same and it was maybe a 2" longer body. i am not sure if having the two pipes being able to someone communicate with each other (each pipe is connected to the same volume stuffed with glass and stainless wool) had any effect.there was an existing rear muffler that remained the same
Joining exhausts of opposite banks has this effect.
If you have lower volume there is less room for expansion of the gasses. So when rpm increases and exhaust gas volume the muffler is already full due to which most gasses just go straight out. My 0.02$
digger
Post by digger » Fri Sep 01, 2017 7:37 pm
i should mention that i also already had an x-pipe upstream so each pulse was already being sent(split) to both of the separate hotdogs
FirstEliminator
Post by FirstEliminator » Fri Sep 01, 2017 8:27 pm
https://www.summitracing.com/parts/aph-xs0416
https://www.summitracing.com/parts/sum-630805
These are the two glass packs I am looking at. The Summit has internal louvers and the AP has a perforated core. Which one would have a quieter note?
thanks,
Mark
Post by pdq67 » Sat Sep 02, 2017 1:06 am
I personally would go with the smooth perforated inner pipe glass pack muffler.
And I would try to install as much perforated pipe as I could!
engineguyBill
Post by engineguyBill » Sun Sep 03, 2017 4:41 pm
Jegs has some short glass-pack mufflers (maybe the same vendor as Summit) that I have used with Walker turbo mufflers. Good results.
Bill
SAE Member (25+ years)
ASE Master Certified Engine Machinist
- Theodore Roosevelt
Post by pdq67 » Mon Sep 04, 2017 6:08 am
Does W/D/T still sell the long, "side-pipe", smooth perforated inner pipe real glass packs anymore??
dave brode
Post by dave brode » Tue Sep 05, 2017 5:53 pm
Mark,
Fwiw, I'd avoid the louvered version, regardless of direction installed. Although as a pair of mufflers alone, they are loud, the race magnum bullets work well as a resonator. I bet the 18" body would do very well. They now have some in s/s, but way more money than the AP that you showed.
https://www.summitracing.com/search/par ... 20Mufflers
There's also a pricey welded version, similar to the AP that you showed.
https://www.summitracing.com/parts/wlk-17230/overview/
Dave
MikeB
Post by MikeB » Wed Sep 06, 2017 9:46 am
Adding Summit Racing brand 12" glass packs to a dual exhaust system in my old pickup with Flowmaster 50 mufflers got rid of most of the drone. Can't speak to power loss, but if I ever do it again, I'd probably use glass packs with 1/4" -1/2" larger pipe diameter adapted to the exhaust pipes.
Post by pdq67 » Wed Sep 06, 2017 5:25 pm
I have asked before,. but I don't think that I ever got an answer back?
What would happen if I installed an open expansion chamber shoe box on the intake end of the long, side-pipe W/D/T real glass packs by 1st bell-mouthing and bull-nosing the mufflers intake out to help funnel the exhaust gasses through the muffler???
one finger john
Post by one finger john » Wed Sep 06, 2017 9:28 pm
HotRodRay
Post by HotRodRay » Tue Sep 12, 2017 2:44 pm
NEW or very long glasspacks sound ok, regardless of design. BUT, BUT, they always get louder, quickly. Often the drone changes.
This year we have a pile of Flowmasters and burned glasspacks removed because the owners hated them.
Stories of Dynamax Super Turbo and Magnaflow with glass indicate they deteriorate more slowly.
I remember one guy had 2 glasspacks on each side, but it sounded wierd after a while.
I have about given up on mine and am seriously considering stock type mufflers... realizing that I don't have 4 cats, the new type mufflers might be (louder) mellow enough ... consistently.
Noise is fun if its a Saturday night deal. After 100 miles it is xxxx.
Oh, by the way.
David Vizard invented the Dynamax Super Turbo. Didn't he?
ptuomov
Post by ptuomov » Wed Sep 13, 2017 8:16 am
The Borla mufflers that I've used are pretty loud straight out of the box but don't seem to degrade over time, despite the basic design of packed chamber with a perforated tube thru them. This may be partially related to why those Borla mufflers are a little more expensive than most mufflers. in terms of longevity, the packing material is key and to a large extent you seem to get what you pay for.
The straight thru design with a packed chamber seems to be where the industry has converged as far as the universal performance mufflers are concerned. It's a really good at attenuating broad-band noise. Combining that with a tuned resonator to take out any remaining problem frequencies and selecting the pipe lengths sensibly will complete the system. Combining pulses for some distance in a cross-plane V8 also takes out a couple dB.
I think that the Dynamax Super Turbo sort of a design which makes two 180-degree turns is at this point an obsolete design. It was much better than the stock mufflers way back when it was introduced, but time has passed on.
Just opinions, on sound I think its mostly a question of taste and local laws/enforcement.
HotRodRay wrote:NEW or very long glasspacks sound ok, regardless of design. BUT, BUT, they always get louder, quickly. Often the drone changes.
Oh, by the way.
[b]Paradigms often shift without the clutch[/b] -- [url]https://www.youtube.com/watch?v=cxn-LxwsrnU[/url]
Post by pdq67 » Wed Sep 13, 2017 11:51 am
The old-fashioned, "steel-packs", are heavy, but they don't burn out!! You can crush fiberglass in your hands so that is how fragile it is. Add exhaust velocity, heat cycling, and condensed exhaust gas liquids and fiberglass goes away fast.
Are, "smitties", steel-packs? If they are, the only problem with, "smitties", is that they are louvered inner pipe vs perforated and only come in like one inner pipe diameter if not mistaken and it is generally too small for a real high performance engine, imho. Of course, we can parallel them to gain more flow!
I will say that a, "pumpable", refractory ceramic fiber material is made that once heated, hardens into a light-weight monolithic fiber material, but it is pricey! I've played with it in my hands. Neat stuff. I think the hardening agent is no more than, "water-glass"...
FirstEliminator
Post by FirstEliminator » Mon Oct 02, 2017 11:19 pm
Tonight, I put a 14" perforated resonator from AP exhaust on my tail pipe after the axle followed with 10 inches of pipe before the tip of the outlet. I can say -----so far----- the droaning is about 90% gone. I haven't had much chance to spend time driving, but it is dramatically reduced in the range the noise was worst.
thanks for all the replies,
Mark
Post by pdq67 » Tue Oct 03, 2017 6:31 am
Back when I had my .060" over 409 "W" 11.5 to 1 engine in my car, I had a 2.5" x 18", a 12" and a small 2" x 12" real smooth perforated inner pipe glass packs down each side of my '67 Camaro and it was loud to say the least! I loved it!
They were the old but new back then, "can", Woodpecker Thrush mufflers!
