That is true. It is also true that a bending wrist pin applies loads to the piston bore in several concentrated locations.cgarb wrote:That would be true if the pin is supported by the very ends. Inside a wrist pin bore I would think the pin would be somewhat supported on each end, so most of the loading of the pin would be between the gap from the rod to the pin bore.
The actual pin deflection depends not only on pin length, OD and ID, but also on the geometry of the piston pin bores.
The topic has been subject of intense FEA analysis studies by major piston manufacturers for many years.
