Building a Chevy 427 by scratch
Harleyboy14
Re: Building a Chevy 427 by scratch
Post by Harleyboy14 » Sat Oct 28, 2017 5:45 pm
Newold1 wrote:
Sat Oct 28, 2017 5:37 pm
Nice input Schurkey and MadBill. Nice of you Harleyboy 14 to pay attention to the input these guys are sharing with you and to take your time to do it right! Wise men never stop learning or listening.
The help from you guys is greatly appreciated. It's been over 20 years since my last full engine build.
Thanks for putting up with me........
CharlieB53
Post by CharlieB53 » Sat Oct 28, 2017 8:19 pm
Harleyboy14 wrote:
Sat Oct 28, 2017 2:59 pm
That was a picture of rings in the bore after I fitted them.
Thank You!
I thought my eyes were deceiving me!
Now, how are the clearances in those lifter bores and the roller lifters you are using? I want to do this to my bored out 396 on her next go round. And 'notch' the intake side of the cyl's.
Harleyboy14
Post by Harleyboy14 » Sat Oct 28, 2017 9:16 pm
Thank You!
I used Howards Retro-Fit Maximum Effort Hydraulic Rollers Lifters. There Tech guy Eric was great help to me. Give him a call.
Harleyboy14
Post by Harleyboy14 » Sat Mar 10, 2018 8:44 am
Update on engine build. Got so busy forgot to take pictures of engine swap. He brought me the car and told me he wanted to upgrade to a Vintage Air sure fit ac system. The car was a factory ac car missing most of the parts. So here we go..... I found this to be a job. As you can see from pictures all the pulleys change and all new brackets. Yes, you have to remove the right hand fender to remove the old evaporator box and repaint firewall. All that's lacking is hose lines and condenser. Sorry to get off subject of build.
The carburetor we installed is a brand new Holly 780 Street Avenger. The distributor used is a MSD Pro-Billet #8360 ready to run type. Most of all thanks to you guys this engine turned out great. Runs and sounds very healthy for a pump gas engine.
Thanks Again,
Art
dwilliams
Post by dwilliams » Tue Mar 20, 2018 5:07 pm
Dave Koehler wrote:
Sun Aug 27, 2017 8:27 pm
The original purpose of the bleed holes was to take care of an air lock at that end of the lifter channel.
If I remember right, solid lifter engines didn't always get the bleed holes.
Harleyboy14
Post by Harleyboy14 » Sun Apr 01, 2018 7:56 am
Need some help on this question. The 427 has ''Lazy return to idle after rev''. I'm doing this with car in neutral sitting still and my hand on carb throttle.
Return just lagging Not Snappy.
Post by MadBill » Sun Apr 01, 2018 9:12 am
Only two possibilities I can think of: either a heavy flywheel or a slight bind in the throttle shaft. (possibly the secondary, since presumably you are pulling the primary closed rather than just letting the return spring do the job)
treyrags
Post by treyrags » Sun Apr 01, 2018 9:32 am
Distributor advance weights sticky?
Casper393W
Post by Casper393W » Sun Apr 01, 2018 10:15 am
Either of these is most likely the cause!
Harleyboy14
Post by Harleyboy14 » Sun Apr 01, 2018 10:31 am
I'll check this out...Thank You...
tjz450
Post by tjz450 » Mon Apr 02, 2018 2:06 pm
Low speed or idle circuit too rich?
