electric water pump part 1 more to come..
hi guys.
i am using a CVR electric water pump on my streeter,i know from previous discussions that some of you guys dont like to use an electric pump on the street and i can respect that,
i am having trouble removing the impeller off the shaft to get to the seal which has started to leak
i dont want to start banging with a hammer and levering with a screwdriver just yet so any advice appriciated,
there is 2 parts to this story but i need to replace the pump seal first
thanks
steve c
thanks
steve c
steve c
"Pretty don't make power"
Re: electric water pump part 1 more to come..
I suggest;
*lightly chuck motor armature in a vice [wrap armature with a rag]
*slip a screw driver or pry bar under each side of the impeller
*carefully apply heat to impeller [a small propane torch or even a hair drier] while holding pressure against impeller.
*post results
*post results
Is the nose of the impeller open so you can see the motor shaft?
Monty Frerichs
B&M Machine
B&M Machine
Larry,
Thanks for the tip,a friend of mine suggested the same thing as yourself last night
I think the aluminium impeller will warm up quickly with a small propane torch and hopefully come off easy,I don't want to damage the anodised housing obviously.
Monty,
The end of the impeller is sealed off as is cast that way,otherwise I may of been able to put in my hydraulic press and press the shaft out of the impeller.
My friend suggested putting the new impeller in a warm oven for a little while to help with ease of fitment,the seal kit includes seal,gasket and a new impeller,this pump is only 6 months old and there is a bit more to the story, I will put up extra photos I have taken after I get this seal deal done, as I have more questions than answers
Thanks guys for responding
Steve c
Monty,
Steve c
steve c
Might be locktited to shaft...if so....as stated a little heat will free it up
jonny5
crap,what is the set screw for?
only joking,yes i took the photo twice and turned out crap both times and yes set screw is removed
going to heat with a butane torch and hopefully fall off
steve c
The screw is a good sign; suggests they aren't relying on a press fit for retention.
This is a trick that's used in restoring antique electric fans.
Find a plastic pipe fitting or similar that's a loose fit over the OD of the armature and extends beyond the length of the armature shaft. Heat the impeller as described then bang the pipe/armature down onto a solid workbench or concrete floor. The weight of the armature pulls the shaft out of the impeller. This gives a uniform pull and might avoid scars from two screwdrivers.
Dave
hi guys,
this was a lot harder to do than i first figured,after applying some heat via butane torch the impeller did free up slightly
i ended up cutting the end off the impeller and having to press the impeller off in my hydraulic press,yes it was that tight but i did not see any loctite
on the shaft it was a very firm interference fit.
thanks to everyone for there input
i am doing a part 2 on this deal as i had some issues after using a cooling system sealing agent which i believe contributed to the waterpump failure in only 6 months of operation
steve c
steve c
steve c
Nefario wrote:This is a trick that's used in restoring antique electric fans.
I like this idea, but it sounds like the OP got it done without damage.
