OEM Block Cleaning techniques
mike fabish
Post by mike fabish »
Does any one know how the OE's clean their blocks before assembly ? Thought someone on here knows, or knows someone who worked in the factory and saw the process firsthand.... Thanks
Go Fast young man, Go Fast-
Keith Morganstein
Re: OEM Block Cleaning techniques
Post by Keith Morganstein »
The cleaning system I've seen (major diesel OEM) was a purpose built, conveyer feed, high pressure, high volume, aqueous solution, with drying, cleaning machine.
ProPower engines
Post by ProPower engines »
Keith Morganstein wrote:The cleaning system I've seen (major diesel OEM) was a purpose built, conveyer feed, high pressure, high volume, aqueous solution, with drying, cleaning machine.
I would bet that is the same for both gas or diesel to take the hands off approach to stop chemical ingestion to the workers.
And faster then a couple guys spray washing and blow drying by hand
ProPower engines
exhaustgases wrote:And meaning no one is using long handle small bore brushes in the Oil GALLERIES. <-----notice the correct nomenclature!
=D> =D>
mike fabish
Thanks for some first hand perspective.. I imagined an assembly line approach and was hoping someone could give us the details....
MELWAY
Post by MELWAY »
They also send high pressure lances up critical oil gallery's
Wolf_Tm250
Post by Wolf_Tm250 »
And mainly a super-filtered liquid, not to push particles in the oil galleries...
What do people use on this forum to clean them?
Wolf_Tm
TM enduro 250cc 2stroke
Toyota Celica Gt-Four ST205 Snowy White
http://www.youtube.com/WolfTm250
EFI University Advanced tuner
