EFI pump regulated to carb?
77cruiser
Re: EFI pump regulated to carb?
Post by 77cruiser » Mon Sep 11, 2017 11:08 am
Tested the flow, 1.5 gal. per minute. Is that enough?
Jim
joe 90
Post by joe 90 » Mon Sep 11, 2017 4:41 pm
340 litres / hour.
Enough for 800 HP or a bit more?
carmakerevive
Post by carmakerevive » Mon Sep 11, 2017 8:14 pm
340 is more than enough.
Hopefully no cavitation occurs.
"Poor planning on your part, does not constitute an emergency on mine..."
77cruiser
Post by 77cruiser » Mon Sep 11, 2017 8:25 pm
Pump is rated at 320 but at 43 lbs. press. I'd guess.
Jim
vortecpro
Post by vortecpro » Mon Sep 11, 2017 8:47 pm
77cruiser wrote:Tested the flow, 1.5 gal. per minute. Is that enough?
On my QJ I had about 3/10 of a gallon in 11 sec, I had problems but it was due to fuel pressure forward out of the pump, stalled fuel in the line on launch. My new fuel system 5/10 of a gallon in 11 sec, but a solid 12 psi forward at that flow, problem solved.
cjperformance
Post by cjperformance » Mon Sep 11, 2017 8:54 pm
Yes its often interesting to run a gauge both before and after the reg if running a dead head system. If pressure between reg and carb drops from say 6lb to 4lb just after launch you can bet the pressure before the reg is doing the same due to launch g.
vortecpro
Post by vortecpro » Mon Sep 11, 2017 9:02 pm
If you run a QJ on a car that leaves.....you better have a good fuel system.
77cruiser
Post by 77cruiser » Mon Sep 11, 2017 9:39 pm
Unlikely I'll see better than high 1.6's It was 1.72 last week.
Jim
