^^ This^^ Should have repaired the original carb (if it actually was the one the car came with) and dist and left it original. No wonder the original carb ran better than a larger aftermarket shiny thing, the original has hundreds of hours of engineering time in it to calibrate it specifically to the original engine. Ditto the original pre-smog distributor calibration. In the long run a nearly virgin vintage original car like that will retain and increase its value, not so likely for something modified. The original engineering goals included maximum reliability and in 1966 Chrysler Corp. cars had the 5 Year 50 Thousand Mile Warranty so they were built to last ..... really. In the lifetime of a passenger car it is incredibly more important how well the carb is calibrated in terms of A/F and DISTRIBUTION at 5% to 15% throttle than how much WOT power it has.PackardV8 wrote:Classic case of mission creep.
Have Daytona Carb rebuild the Carter. Have a distributor shop rebuild his distributor. Put it back stock and leave well enough alone.
stock 383 mopar
Re: stock 383 mopar
Re: stock 383 mopar
Here is what I'd put in that C body: http://www.hotrod.com/articles/holley-hp-efi-install/
Andy F.
AR Engineering
AR Engineering
Re: stock 383 mopar
The OE stuff just isn't snazzy enough.Tuner wrote:^^ This^^ Should have repaired the original carb (if it actually was the one the car came with) and dist and left it original. No wonder the original carb ran better than a larger aftermarket shiny thing, the original has hundreds of hours of engineering time in it to calibrate it specifically to the original engine. Ditto the original pre-smog distributor calibration. In the long run a nearly virgin vintage original car like that will retain and increase its value, not so likely for something modified. The original engineering goals included maximum reliability and in 1966 Chrysler Corp. cars had the 5 Year 50 Thousand Mile Warranty so they were built to last ..... really. In the lifetime of a passenger car it is incredibly more important how well the carb is calibrated in terms of A/F and DISTRIBUTION at 5% to 15% throttle than how much WOT power it has.PackardV8 wrote:Classic case of mission creep.
All about the show and not the go I guess.
Re: stock 383 mopar
This fits by reasoning my understanding of my customers goals changed from the time i started this thread.statsystems wrote: The OE stuff just isn't snazzy enough.
Re: stock 383 mopar
I've learned that the quickest way to get your customer to change his mind after he's already committed is to start a SpeedTalk threadgvx wrote:This fits by reasoning my understanding of my customers goals changed from the time i started this thread.
Re: stock 383 mopar
That all depends upon WHICH carb he bought. The newer Demon caburetors are more like a Carter than a Holley.Baprace wrote:I think the demon carb is where most of his power went, I have never seen one that made great power, even though they are modeled after the Holly carb they seem to work different
The Weiand intake manifold #8009 works really well on a "driver" which needs manners along with power.
The cam chosen is way to big for performance in a "boat" car with stock torque converter and small rear gear.
He complained about the carb change losing power ...? Tell him he will lose a bunch more drive-ability and manners with a cam like that, just so he can get the sound he wants.
Make sure this is HIS decision.
Re: stock 383 mopar
They definitely work different. "Badly" is a kind of different.Baprace wrote:I think the demon carb is where most of his power went, I have never seen one that made great power, even though they are modeled after the Holly carb they seem to work different
But they have great advertising so they MUST be good!
Re: stock 383 mopar
That cam should make drivability a lot better than the other cam I saw, ( 227 x 241 @.050 is too big )the ( 210 x 216 @.050 ) is plenty big enough. JMOAMXstocker1 wrote:If he wants it to work and he's willing to spend money, tell him to do a mild torque converter change 1800-2500 ish stall atleast 3.23 gears headers a perform or performer rpm and i would think a cam similar to this would work HUG SEH1016BL-1
Re: stock 383 mopar
i'd bet this cam would out run the that other cam i saw too.Baprace wrote:That cam should make drivability a lot better than the other cam I saw, ( 227 x 241 @.050 is too big )the ( 210 x 216 @.050 ) is plenty big enough. JMOAMXstocker1 wrote:If he wants it to work and he's willing to spend money, tell him to do a mild torque converter change 1800-2500 ish stall atleast 3.23 gears headers a perform or performer rpm and i would think a cam similar to this would work HUG SEH1016BL-1
Re: stock 383 mopar
I don't know about how they may fit into the chassis, but 383/440 "magnum" exhaust manifolds are a big help over the standard manifolds.
Re: stock 383 mopar
OK!!
S would turning this engine into an old 383", "Road-Runner", engine help here?
Some have said that these old 383" RR engines were a lot stronger than what you would think that they should be.
I do know that a classmate of mine at Moberly Jr. College back then bought a new Road Runner and put something like Sonic M-50 tire's on wide rims on the rear.
Sucker would definitely haul ass! 383", -727, and 3.23's.... At $2995, it was optioned just like a, "Taxi"...
Re: stock 383 mopar
The later 383s without the 516 heads where a far stronger motor above 3800 rpm!
Re: stock 383 mopar
My bought new 69 Super B 383 4 speed 3.23 posi ran 14.5 bone stock...This was typical 383 times from what I saw at many trips to the Englishtown and Island strips in NJ....It was also about the same times you got from most entry level muscle cars, GTO, 442, 396 etc...pdq67 wrote:OK!!
According to Mopar, the 383/335 hp in the SB and RR had different heads,cam, slightly higher compression than the 383/330 used in non performance cars....The stock 335 hp engine on a dyno had about 275 HP based on info published back then...
Re: stock 383 mopar
I had that manifold part number wrong; that one is for a 440 engine. #8008 is for the lower deck block engines.Walter R. Malik wrote:That all depends upon WHICH carb he bought. The newer Demon caburetors are more like a Carter than a Holley.Baprace wrote:I think the demon carb is where most of his power went, I have never seen one that made great power, even though they are modeled after the Holly carb they seem to work different
