600 HOLLEYS
- New Member
600 HOLLEYS
I am rebuilding a pair of 600 Holley vacuum secondary carbs. I have read in various articles there is a hole in the right primary side of the main venturi. it is my understanding this hole controls the operational circuit of the secondaries. neither of my carbs has this hole can anyone tell me where the equivalent to this hole is on my carbs ? THANKS
Re: 600 HOLLEYS
every vacuum secondary holley I ever worked on had a hole in the primary venturi for a vacuum source to open the secondary. some even had hole in the secondary venturi for additional vacuum to help open the secondary.
Re: 600 HOLLEYS
Post up the List #'s off the carbs, so we know what your working with....there are literally a 100 different "600 Holleys".
Re: 600 HOLLEYS
It has to be there, often it has a little shroud over it. Post the LIST number and/or a picture, if it really isn't there, maybe you have a set of mech secondary 450s?
Bullock's Power Service, LLC
Plattsmouth, NE
70 Mustang, 489 FE, TKO-600, Massflo SEFI, 4.11s
71 F100 SB 4x4, 461 FE, 4 speed, port injected EFI, 3.50s
Plattsmouth, NE
Re: 600 HOLLEYS
-this picture shows 1 long wire from passenger side front venturi out thru a hole (with that passage's end plug removed) near where the vacuum pot is mounted--and one other long wire from the right rear venturi area that intersects the first passage---and ends up going into the vacuum pot to pull vacuum on the diaphragm
-this picture is a close up of the passenger side secondary barrel's venturi vacuum supply under the blue scribble line---that helps increase the vacuum pull on the diaphragm.
-this picture shows the short brass piece that is in some passenger side primary venturis ---that increases the venturi vacuum back into the vacumm secondary passaeways.
Re: 600 HOLLEYS
-here's one more showing the outside of the main body where the wires exit.
-the shiny hole where the left side wire exits has had the lead plug removed and it's been threaded for a 10/32 setscrew to be the new plug.
-the hole where the wire comes out towards the center of the picture is the passage that connects to the vacuum chamber---normally uses a cork gasket or an O-ring to seal up that connection.
