Ring end Gaps
Re: Ring end Gaps
I wonder if some of the confusion isn't due to ring gaps being both a spec. and a wear indicator? E.g., finding that the gap averages 0.040" on rings you installed at 0.016" years ago is different than file-fitting it to 0.040" to start with.
Re: Ring end Gaps
It won't.wilson1970 wrote:I will leave the one at .024" at hope .004" doesnt matter
Paul
Re: Ring end Gaps
Ring "wear" won't have much affect on ring gaps, one way or the other. Most ring wear takes place on the lateral surfaces of the rings and is accompanied by similar wear within the piston grooves. Even rings that exhibit significant wear in this area will still have pretty close to the same gap that they had when originally installed in the engine.MadBill wrote:I wonder if some of the confusion isn't due to ring gaps being both a spec. and a wear indicator? E.g., finding that the gap averages 0.040" on rings you installed at 0.016" years ago is different than file-fitting it to 0.040" to start with.
Bill
SAE Member (30 years)
Re: Ring end Gaps
If you've got 0.008 inch wear in a bore, you're going to see at least an extra 0.025 inch extra ring gap.
That's just from wear in the bore , not counting wear in the rings.
A common limit on bore wear is often about 0.003 inch, so that's at least an extra 0.013 inch end gap.
- Show Guest
Re: Ring end Gaps
Your very wrong this time Bill- I have seen the butt gaps grow to 040, even more
JOE SHERMAN RACING
JOE SHERMAN RACING
Re: Ring end Gaps
0.003" bore wear = 0.0094" ring gap increase.
Re: Ring end Gaps
Yes, got my multiplication a bit wrong.MadBill wrote:0.003" bore wear = 0.0094" ring gap increase.
Re: Ring end Gaps
On a 4.125" bore I filled my top and second rings to 0.022". The top ring, according to specs could have been a little smaller (like .018") but I didn't want any risk on rings butting an causing havoc on the engine when the operating temps would go up for one reason or another or I would run into detonation.
Re: Ring end Gaps
Are you using a street engine factor? On my perfect circle rings they call for .0055x4.050(bore) =.0222 top bottom. I thought if he adds juice to loosen them up. I typically go .002 than ring spec for added assurance. http://www.rlengines.com/tech/speedprorings.pdf. Here on speed pro chart they do call for larger second gap. Perfect circle doesn't.
Re: Ring end Gaps
I've run as tight as .022 top on a 4.500" bore, street engine with a 250 shot. SpeedPro chromemoly 1.5mm. Engine ran like a champ for 6 years, looked beautiful when I disassembled it.
Currently running .032 top on a 3.810" bore with 30 lbs of boost. TS gapless.
I'm with the gang- it matters when it's too tight.
Re: Ring end Gaps
I see ok. When I used to run the old .014-.010 gaps would always get that tell tale streaking in bore. Thats when i talked to super stock racer and he said looser the better his motto on rings.
Re: Ring end Gaps
I agree, cylinder bore wear and ring wear will affect the gap to some extent, by the factor of Pi (3.1415). BUT, if you have .003" to .008" wear in the cylinders, the piston grooves and the ring lateral surfaces are toast and the engine totally worn out so it doesn't really matter what the ring gap is. In summary, as long as the engine remains healthy, the ring gap will remain consistent with the original dimension, or very, very close to it.
Bill
- midnightbluS10
Re: Ring end Gaps
While doing some searching on this subject, I've come across this page:
http://www.diagnosticengineers.org/jour ... 20Gaps.php
Does that make sense? He covers quite a bit of stuff. Even touching on things such as ring gap stagger being useless... The Ford Kent engine is the 1.6L to 2.0L SOHC used from the 80s to the 2000's in the Ford Escort and Focus.
Thanks guys.
Ring Gaps vs Knowledge Gaps
During school summer holidays there occurs a period known as the "silly season" when breaking news is slack and newspapers, radio and TV issue forth all sorts of drivel to justify their existence.
In our industry I sometimes think that we use ring gaps to fulfil a similar purpose – and we do it all year round. There are more old wives tales about ring gaps than any other facet of our job, so lets spend a while and bin a few of them.
Frequently I hear in court that when an engine is dismantled it is discovered that the ring gaps were not staggered when they were installed. Frequently I read workshop manuals that go into great detail on the necessity to stagger ring gaps. Frequently these manuals specify ring gap limits – which is yet another myth we can bin before we are finished.
In days gone by, some compression rings used to have a ‘threepenny bit’ expander behind them. These braced against the base of the ring groove and forced the ring onto the cylinder bore but these are very much the technology of yesteryear and, as such, an exception to what I am about to say.
Piston rings are free agents and can rotate or not rotate as they see fit. They are not in touch with the base of the groove and neither are they trapped between the upper and lower faces of the groove. The rings are entirely free to rotate – except where a stop peg is fitted – so what's the point in staggering the gaps on installation?
We used to work on a minimum of 0.020" back clearance on radius or, to put it another way, the inside diameter of the ring when installed in the cylinder must be at least 0.040" bigger than the groove root diameter. Minimum side clearance was generally held to be 0.0015" and if you could fit a 0.006" feeler gauge in the groove along with the new ring then the groove was "goosed" so the piston was replaced.
The piston ring was manufactured with a tangential load – the force with which the ring presses against the cylinder wall – but apart from that it is completely uncontrolled. There is no way, under these circumstances, that you could prevent the ring from turning so, to repeat the question, why stagger the ring gaps on installation?
Staggering ring gaps when installing pistons is every bit as daft as having four tyres fitted and placing all the valves at "twelve o'clock". One trip to Tesco and they end up all over the place.
Equally daft are those who expect ring gaps to stay staggered when the engine is in operation. When there is clearly nothing to prevent the ring from rotating, why should the gaps stay staggered?
More than one county court judge has fallen for the hocus pocus that because the gaps were in line when the engine was dismantled, they must have been in line when installed. Absolute poppycock! Yet the inclusion of such rubbish in workshop manuals does admittedly give it an air of authority.
When you think about it, you don't need me to tell you – but I will anyhow – that rings do rotate in operation. Every now and again the gaps do line up – and once lined up there is a tendency for them to stay lined up at least until the vehicle hits the next pothole in the road when one or other will rotate and break the line. Staggering ring gaps when installing rings is a myth that we can bin forthwith.
Even worse is the preoccupation with the size of the ring gap. Yes, there is a minimum but this varies considerably depending on the material used. Normally 0.003"/0.004" per inch of bore size is given but where, for example, low expansion SG (spheroidal graphite) iron is used, it can be considerably less.
It’s no problem if the gap is too small because it can, in the final analysis, be filed bigger but what do you do if it's too big? You cannot stick a bit extra in there!
Well, the answer to that was that you melted them down and started afresh – until AE research asked the question, "What is too big?" and set out to quantify that. The results were interesting – very interesting – and what you are about to read was kept quiet because it bestowed an enormous commercial advantage on AE. This is probably the first time the information has been published although the research was undertaken in the late 1970's – almost 25 years ago.
A Ford Kent engine was stripped and fitted with compression rings which had end gaps of 0.015" when fitted in the bores. The engine was wired up with the usual telemetry to measure blow-by and oil consumption and then run in one of the test cells. After making due note of the blow-by and oil consumption, the engine was stripped and fitted with new compression rings with gaps of 0.025" and the test cycle repeated.
These rings were subsequently replaced by ones having end gaps of 0.035" and the test cycle repeated again. It had been planned to stop at 0.035" gaps ----------> but the results were so interesting that it was agreed to proceed to 0.045” and then not to 0.0055” but to 0.0625” – 1/16"!
Whoever heard of rings with 1/16” gaps – a ridiculous figure – but the interesting thing was that the increase in blow-by and oil consumption at 0.0625” was only marginally above the figures obtained with 0.015” gaps.
Practical tests established that the gap was not the villain of the peace. To all practical purposes the size of the gap didn’t matter. It is important to stress at this point that we were dealing with compression rings that were brand new when fitted to the test engine.
The gap was specially manufactured for the tests. So how come all oil burners and heavy breathers have ring gaps you can back a bus through? Well, the tangential load that the ring exerts onto the cylinder wall is a direct function of its radial thickness.
As the periphery wears in contact with the bore, the radial thickness obviously decreases, as does the tangential load. Peripheral wear means a smaller ring o/d and this manifests itself as an increase in the ring gap.
So, whilst all oil burners and heavy breathers have big ring gaps, it's not the gap but the reduced tangential load that is detrimental to the performance of the engine. The ring gap is a complete red herring.
Imagine four top compression rings all with 1/16” gaps. The total gap for all four would be 1/4”. Now imagine the seal provided in an 80 mm diameter bore. Pi x Diameter = Circumference, so we have 3.14” x 3.15” = 9.891”. Multiply that by four cylinders and we have 39.564” – over a yard of contact seal between piston rings and bore. Now visualise the many litres of blow-by and consider whether all the gas is squeezing through 1/4” of total gaps or passing through 39½” of reduced pressure contact seal!
But even this ignores one important facet of the argument because there is not just the one compression ring on a piston – there are usually at least two and that is because rings work as a team to form a labyrinth seal.
For gaps to be the villain of the peace, the gas would have to find the gap in the top compression ring and pass through. It would then have to circulate to find the gap in the second ring and pass through that and so on. Now this may be possible if the power stroke lasts for 10 minutes but it doesn't, does it?
At 3,000 rpm the power stroke duration is a mere 1/100second. Quite simply, the power stroke does not last long enough for the combustion gas to find its way around the maze – or labyrinth seal, so the villain of the peace has to be the reduced tangential load of the ring on the bore caused by peripheral wear or reduced radial thickness of the ring.
This was our hypothesis based on the results obtained in the engine test cell but it took a very clever American to prove it. This genius invented telemetry that measured gas pressure between the piston rings in a working engine.
Use of his brainchild revealed that some gas did get through the top ring gap sufficient to generate a hell of a pressure between the top and second rings – so it clearly was not finding the gap in the second ring. The labyrinth was working well. Caterpillar and IHC must have thought it was working too well because they increased some second ring gaps to 0.050” and 0.070” thought to be beneficial.
Come to think of it, the exception proves the rule – as usual. Two stroke engines would not need stop pegs to prevent the end gap from crossing a port if the ring didn't rotate. The people who allege that ring gaps were not staggered when installed just because they are in line when the engine is dismantled don't need stop pegs.
They could simply position the end gap away from the port and expect it to stay there – and we all know that this would get them into more hot water than a Yorkshireman’s tea bag! So why do they always blurt out their rubbish on the importance of staggering gaps?
The very presence of a stop peg also proves my point about the size of ring gaps. Where a peg is fitted, the end gap has got to be 1/8” to accommodate the peg. There would be one hell of a draught through that if the 0.015”/0.018” boys were correct.
This knowledge was commercial dynamite because, instead of the '0.015”/0.018” spec., it meant that new rings with gaps over 0.018” could be used without any detriment to the engine's performance. The gap was only detrimental when it was the result of peripheral wear. Customer acceptance was the only problem.
To re-educate the customer would let the cat out of the bag, thereby losing the distinct commercial advantage. It was decided, therefore, to accept rings with gaps of up to 0.030” in a nominal bore but even then there were arguments. 0.030" in a nominal bore is 0.045” in a bore worn by 0.005” – and it's normally engines with this sort of wear that get new rings.
The gaps on the new rings were bigger than the gaps on the ones being replaced which led to several heated conversations – and how the hell do you pacify the customer and keep the cat in the bag?
It made diagnostics a lot harder too because when all rings set off in the 0.015”/0.018” area gaps of .040” meant something but now, when you don't know what they set off at, what they measure is meaningless.
Well, now you know. All rings are free agents to rotate as they like, making staggering of gaps on installation a joke and ring gaps are not a problem provided that the gap is not the manifestation of reduced ring radial thickness caused by peripheral wear.
In the light of the logic expressed in this article we are offering an expensive prize to anyone who gives us a good reason for staggering ring gaps on installation – a free burial at sea.
M H Booth F.I.Diag.E
Thanks guys.
Last edited by midnightbluS10 on Sat Aug 19, 2017 4:41 am, edited 1 time in total.
JC -
Re: Ring end Gaps
That's a good article, If the cross hatch is correct, the rings rotate so of course they will align at times. End gaps are not critical(within reason) unless too tight.
Kinda funny when the z-gap and total seal seconds were the greatest things ever for leak down, there were a few of us wondering what happens when the top ring leaks a bit, or rattles(bad tunes and bad nitrous) and unloads the second stopping it from helping the oil ring? Well, durnit tighten up the top ring Oh well, the lower rpm tractor guys figured it out.
-Carl
-Carl
