Brodix Track 1 "X" heads
Dragsinger
Post by Dragsinger » Sun Aug 13, 2017 12:38 pm
When building a 23* drag race SBC with 4.155 bore and 3.80 stroke is the Brodix Track 1 X and a good choice? Expect to produce about 700 horse with an operating range of 6400 - 7800 RPM
Larry Woodfin, Flyn with the Race Bird
bigjoe1
Show Guest
Show Guest
Re: Brodix Track 1 "X" heads
Post by bigjoe1 » Sun Aug 13, 2017 1:38 pm
If you are thinking out of the box== AFR is a much better choice
JOE SHERMAN RACING
Dragsinger
Post by Dragsinger » Sun Aug 13, 2017 1:55 pm
Joe, not necessarily out of the box, although that would be OK.
The goal is a SBC, 23* head that will run 6.0 ET 1/8 mile at 3100 pounds with driver. Doing so will require about 408 CI, 700 horse with an operating range of 6400 - 7800 RPM [all the above appromiximate] [most likely with methanol]
Given that, which AFR head will accomplish that goal?
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 » Sun Aug 13, 2017 2:26 pm
The AFR 220 competition CNC ported will work very well on that size engine
JOE SHERMAN RACING
mag2555
Post by mag2555 » Mon Aug 14, 2017 7:18 am
For making 700 hp on meth I would like to see 320 cfm @ .650" lift out of the Heads used and the track 1X do not hit those numbers out if the box.
Walter R. Malik
Post by Walter R. Malik » Mon Aug 14, 2017 10:39 am
Dragsinger wrote:When building a 23* drag race SBC with 4.155 bore and 3.80 stroke is the Brodix Track 1 X and a good choice? Expect to produce about 700 horse with an operating range of 6400 - 7800 RPM
If you want to use a Brodix head then I would opt for the 18X heads; 18 degree but, with 23 degree exhaust pattern and uses 23 degree stud type rocker parts.
