Need 6.1 Hemi Valve Seals with .525" Guides
bigpoppapreston
Post by bigpoppapreston »
I Need 6.1 Hemi Valve Seals with .525" Guides. Looking for viton steel body seals but i cant find any for .525" diameter guides. The closest that I see are .530". Will the .530 seals work and be tight enough or just settle for the flex body viton seals. Thanks in advance.
-Poppy
Walter R. Malik
Re: Need 6.1 Hemi Valve Seals with .525" Guides
Post by Walter R. Malik »
bigpoppapreston wrote: I Need 6.1 Hemi Valve Seals with .525" Guides. Looking for viton steel body seals but i cant find any for .525" diameter guides. The closest that I see are .530". Will the .530 seals work and be tight enough or just settle for the flex body viton seals. Thanks in advance.
I got my 6.1 hemi valve seals at the Dodge Dealer.
bigpoppapreston
I should've mentioned that im going with manley locators and wanting to get away from the top hat style seals by using ordinary viton valve stem seals. Reason being is that i have retainer to seal clearance issues with the top hats. My camshaft is .595" both on the intake and exhaust.
-Poppy
bigpoppapreston
http://www.valveseal.com/v-high%20perfor.html
U.S. Seal in Fort Gratiot Michigan may have what I need. Will check Monday.
-Poppy
Newold1
Post by Newold1 »
Check with the guys at:
www.precisionengineparts.com
bigpoppapreston
Newold1 wrote:Check with the guys at:
http://www.precisionengineparts.com
Thanks Newold1!
-Poppy
Frankshaft
Post by Frankshaft »
Also, if you had to, cut them to .500. I used to do that all the time on vortec heads. Cut the .550 seal to .530, and run the seals I like that I usually have on hand.
jsachs1
Post by jsachs1 »
Harley Davidson sources a viton seal part # 18067-09 that may work for you. Only thing is price wise they're EXTREMLY proud of them.
John
