Ford 5.4 rebuild help
JonKaase
Post by JonKaase » Fri Aug 11, 2017 12:45 pm
After 455,000 miles, we are rebuilding the 5.4 motor in my Harley truck. (Factory blower)
If we reuse the rod and main bolts, what would be the torque needed to make them happy? I think they are torque to yield. So you can't torque to an angle like new bolts. Will this work? Kaase
DaveMcLain
Re: Ford 5.4 rebuild help
Post by DaveMcLain » Fri Aug 11, 2017 1:26 pm
JonKaase wrote:After 455,000 miles, we are rebuilding the 5.4 motor in my Harley truck. (Factory blower)
That's the engine that beat my T bucket when we raced at the drag strip!
On the last one of those I rebuilt a couple of months ago I used new bolts from Ford in the rods and mains, even though many people re use the stock bolts including the 90 degree torque to yield step. I didn't do that because I didn't know how many times this engine had been apart. In your case you could probably use them again without trouble.
I just looked and the part number is F3LY-6214-A for the rods.
Carnut1
Post by Carnut1 » Mon Aug 14, 2017 12:41 pm
I would not reuse a torque to yield fastener! If I had before and after fastener length records maybe, if the length returned to the original length but the definition of torque to yield lets you know that the fastener is a one time use item. Too risky for an engine that has been so reliable. Thanks, Charlie
