I'm definitely with you there. But now we're going to have drag race these engines with optimized gearing........nitro2 wrote:It matters, but you can have two engines with the same average HP over the same rpm range and depending on the shape of the HP curve, one will accelerate the same car with the same gearing, quicker than the other.plovett wrote: I think average hp is what really matters when accelerating a vehicle.
paulie
Race Engine Challenge
Re: Race Engine Challenge
plovett wrote:I'm definitely with you there. But now we're going to have drag race these engines with optimized gearing........nitro2 wrote:It matters, but you can have two engines with the same average HP over the same rpm range and depending on the shape of the HP curve, one will accelerate the same car with the same gearing, quicker than the other.plovett wrote: I think average hp is what really matters when accelerating a vehicle.
paulie
LOL. Could be done with the right dyno type AND the right formula to go with it.
High Speed Combustion Pressure Tuning Equipment
TFX Engine Technology Inc.
tfx.engine@yahoo.com
www.tfxengine.com
www.tfxengine.com
Okay, but might it depend on all sorts of other variables like the weight and drag, of the hypothetical vehicle the engine is going in? Just for starters? Also length of race (mph), traction, number of gears, etc. etc. etc.nitro2 wrote:plovett wrote:I'm definitely with you there. But now we're going to have drag race these engines with optimized gearing........nitro2 wrote:
I'm for the K.I.S.S. principle whenever possible.
JMO,
paulie
plovett wrote:Okay, but might it depend on all sorts of other variables like the weight and drag, of the hypothetical vehicle the engine is going in? Just for starters? Also length of race (mph), traction, number of gears, etc. etc. etc.nitro2 wrote:plovett wrote:
JMO,
paulie
Not really. You just want to race an engine, not a car.
www.tfxengine.com
www.tfxengine.com
I think the point of the contest is to "race" engines.nitro2 wrote:plovett wrote:Okay, but might it depend on all sorts of other variables like the weight and drag, of the hypothetical vehicle the engine is going in? Just for starters? Also length of race (mph), traction, number of gears, etc. etc. etc.nitro2 wrote:
JMO,
paulie
plovett wrote:I think the point of the contest is to "race" engines.nitro2 wrote:plovett wrote:
JMO,
paulie
Well that may be the "intended point" of the contest, but I have yet to see any EMC or other contest where an engine was effectively "raced" against the others, and for that matter precious few dyno tests from anywhere, ever, that accomplished it either.
www.tfxengine.com
www.tfxengine.com
Okay, well I guess you need to start your own contest where all the engines are dyno-ed, then put in the same car, with optimized gearing for each engine, and run down the track, hopefully under the same weather conditions and with identical track prep, and driven equally well. That would be cool.nitro2 wrote:plovett wrote:I think the point of the contest is to "race" engines.nitro2 wrote:
Pretty much the same thing can be accomplished with an engine inertia dynomometer .. they can even simulate shifting gears and RPM drop.plovett wrote:Okay, well I guess you need to start your own contest where all the engines are dyno-ed, then put in the same car, with optimized gearing for each engine, and run down the track, hopefully under the same weather conditions and with identical track prep, and driven equally well. That would be cool.nitro2 wrote:
Most are electric and around half a million dollars.
Last edited by Walter R. Malik on Sat Aug 12, 2017 11:12 am, edited 1 time in total.
Sounds good to me. It would be interesting for sure.Walter R. Malik wrote:Pretty much the same thing can be accomplished with an engine inertia dynomometer .. they can even simulate shifting gears and RPM drop.plovett wrote:Okay, well I guess you need to start your own contest where all the engines are dyno-ed, then put in the same car, with optimized gearing for each engine, and run down the track, hopefully under the same weather conditions and with identical track prep, and driven equally well. That would be cool.nitro2 wrote:
Most are electric and half a million dollars.
For the sake of progress and development, I think there should be two classes; NA and forced induction.
The competition would be to see who could develop the highest BMEP. Period. That would normalize
for size. A secondary option would be BMEP divided by rpm.
LOL. What happened to the KISS principle.plovett wrote:Okay, well I guess you need to start your own contest where all the engines are dyno-ed, then put in the same car, with optimized gearing for each engine, and run down the track, hopefully under the same weather conditions and with identical track prep, and driven equally well. That would be cool.nitro2 wrote:plovett wrote:
Yeah an inertia dynamometer is needed, then it needs to be run the right way.
www.tfxengine.com
www.tfxengine.com
These are your ideas, not mine. I was just trying to be nice.nitro2 wrote:LOL. What happened to the KISS principle.plovett wrote:Okay, well I guess you need to start your own contest where all the engines are dyno-ed, then put in the same car, with optimized gearing for each engine, and run down the track, hopefully under the same weather conditions and with identical track prep, and driven equally well. That would be cool.nitro2 wrote:
I like just averaging hp over the specified rpm range. Simple and useful.
An inertia dynamometer with the right measurement parameter, is a lot better test than a regular dyno sweep test, and every bit as simple (assuming performed without gear changes and all that sort of thing). It's just not cheap.
That being said, one could also take a regular dyno sweep test and determine which engine would win on an inertia dyno roll on test, still keeping with the KISS principle. Just a formula, and all these contests use formulas of one sort or another to determine the winner.
Average HP is fine if there is a significant difference in average HP between 2 engines, but it's just not a good way to evaluate 2 engines that have pretty close to the same average HP.
www.tfxengine.com
www.tfxengine.com
What could we learn if each engine had in-cylinder pressure equipment? That would be cool alongside the dyno sheets.
-Carl
-Carl
- Stan Weiss
Doing a standard xxx RPM dyno test has the engine see a variable load during the dyno test.
The inertia dyno will have a fixed load on the engine and show a variable RPM acceleration. The highest RPM acceleration rate will be around peak torque.
Stan
Stan
