427 truck block oil pressure fitting
engineman1642
Post by engineman1642 » Tue Aug 08, 2017 3:29 pm
I have a customer who has a 427 chevy truck block ,sez fitting above oil filter is neither 1/4 or 3/8 pipe.Anyone know what it might be? thanks
machinedave
Re: 427 truck block oil pressure fitting
Post by machinedave » Tue Aug 08, 2017 3:51 pm
I have one in the shop now. I just checked it and it is 3/8" pipe.
SupStk
Post by SupStk » Tue Aug 08, 2017 4:43 pm
+1
Also have one here and its 3/8 pipe.
Monty Frerichs
B&M Machine
Newold1
Post by Newold1 » Tue Aug 08, 2017 6:27 pm
The 427 tall deck truck block I have in my shop is also a 3/8"npt size threaded hole above the oil filter pad as shown above.
someone may have taped it out to a larger size like a 1/2" pipe or #10AN size. Seen this done many times for a remote oil filter or cooler setup.
engineman1642
Post by engineman1642 » Tue Aug 08, 2017 7:45 pm
have not seen the block ,but he said that 1/4 " fitting falls into thread and 3/8" is way bigger than the thread in block.
SupStk
Post by SupStk » Tue Aug 08, 2017 11:10 pm
Guess I've never seen the oil port above the filter in a BBC that wasn't at least 3/8 NPT. There are blocks that are even bigger but not in truck engines, from what I've seen.
Wonder if there is something, such as a reducer, adaptor or some other fitting screwed in the hole?
Monty Frerichs
B&M Machine
gramps
Post by gramps » Fri Aug 11, 2017 8:12 am
Had same deal SBC bowtie block lower water drains, ended up being 9/16-18 thread or AN6 plug.
pamotorman
Post by pamotorman » Fri Aug 11, 2017 9:11 am
I have gotten used SBC blocks with 3/8 NTP plugs in the water jacket drains. most like the original 1/4 NTP threads were stripped,distroyed or rusted out.
