390/428 FE Strokers
blykins
Re: 390/428 FE Strokers
Post by blykins »
I don't know how many 4.250" cranks I've used in FE's.....uncountable. Never had a rod/cam issue. It starts getting close with a 4.375" crank, but with the right rod, there's still enough clearance.
I think you have something else going on. Some of the older Scat cranks had counterweights that were misshapen. They were contacting the wrist pin bosses on the pistons. Check that first...
Lykins Motorsports
brent@lykinsmotorsports.com
www.lykinsmotorsports.com
www.customfordcams.com
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
GIVE THE MAN A CIGAR ! That is what it was==
JOE SHERMAN RACING
blykins
Post by blykins »
Little harder to fix, but glad you got it nailed down.
Lykins Motorsports
PackardV8
Post by PackardV8 »
Glad you got good advice on exactly where to look. That counterweight to piston clearance thing once nearly drove me nuts on a Packard V8 being run in before being shipped to England. Good thing we did run it, as there was a noise which got louder as it warmed. Pulled the pan, pulled the rod bearings and rechecked the bearing clearances. Stock cam and crank, so no interference there. Finally, I saw a smudge of aluminum on a counterweight. These were aftermarket cast stock replacement pistons and had always cleared before, so I had looked everywhere else first for that little knock. The piston skirts were left as cast and one edge was barely ticking against one counterweight. Six extra hours of shop time, two minutes with a half-round file, a new pan gasket and the Packard V8 was on the way to England.
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
A good friend at SCAT told me where to look-- Thanks guys !
JOE SHERMAN RACING
My427stang
Post by My427stang »
Good stuff, Brent sure has lugged a few SCAT FE cranks across the shop!
Bullock's Power Service, LLC
Plattsmouth, NE
70 Mustang, 489 FE, TKO-600, Massflo SEFI, 4.11s
71 F100 SB 4x4, 461 FE, 4 speed, port injected EFI, 3.50s
blykins
Post by blykins »
If the aftermarket FE block quality doesn't go up, I won't be lugging any more. 'Bout done with them.
Lykins Motorsports
