46 deg top cut, then into a radius chamber cut. 65 deg bottom cut.Can you share what top cut angle you used with the 50 deg seat?
Super stock iron heads - work in progress
Re: Super stock iron heads - work in progress
very clean work makes me miss grinding!!
Guy on corvetteforum in the C3 tech needs some heads from you . In your neck of the woods
Nice work Tony, they should go nicely on a MS engine
Alan Jones
It's Ok to disagree, just don't be disagreeable!
