Porting Vortecs???
Re: Porting Vortecs???
New dilemma. Pushrods are .025 short, using the blue pro form rocker arm tool. What change would it make using them and straight up or slightly taller rods?
The pushrods appear to now the be too short because you now are using a thicker (.039" composite) than factory OEM head gasket. Swap the .039" head gasket for a .015" shim style felpro 1094 gasket and the pushrods will suddenly be .025" longer. If your piston sits below the deck at TDC this is the head gasket U want anyway. Now your real cr will be a bit higher too.
(piston to deck clearance at TDC .020-.025") Felpro #1094 head gasket.
.025" off from being dead on would not worry me!
I don't think I'd be worried about .025 or .050 if I was using a plastic proform tool to check length with.
Pretty sure if you check length via the "90°rocker centerline to valve CL at half lift", one or other of those two lengths will be closer than where you are now.
2X re not trusting the plastic gauge.
Power output estimate(ballpark)?
Cleaned exhaust ports but opened the exhaust throat behind the valve, intake side was smoothed behind the valve as well. Rolled back guides bosses lightly. 5 angle valve job with 194/150 valves. 235d isky valvesprings.
750 Holley with 850 base, 1" spacer allowed.....I have an open one and 4 hole one to use if needed. 70/30 mix of 91 octane and 110 race fuel.
2716 Edelbrock intake, porting not allowed
elgin pro stock 1133 cam, 246/246 .050 106/110 -108/advance 4 degrees. 1.5 rockers
.040 2256L forged sealed power piston 5/64. 5/64. 3/16 rings
5.7 stock rod, arp bolts. 10/10 cast crank 3.480 stroke
dirt oval, 1/4-3/8 , on american racer kk704 tires.
.025 below the deck, likely running .039 stock head gasket with a roughly 67-68cc head chamber. 9.3-9.4 comp,
3000-6800 range, with a 7000 limiter
With it .025 below deck I would have some felpro 1018 steel shim gaskets on that one real fast. Get you some extra compression for cheap. They are decent head gaskets also.
- psychomotors
Or Felpro 1094-even better,lol.cgarb wrote:With it .025 below deck I would have some felpro 1018 steel shim gaskets on that one real fast. Get you some extra compression for cheap. They are decent head gaskets also.
Err... yeah, since a 1018 is a 0.041" BBC part...psychomotors wrote:Or Felpro 1094-even better,lol.cgarb wrote:With it .025 below deck I would have some felpro 1018 steel shim gaskets on that one real fast. Get you some extra compression for cheap. They are decent head gaskets also.
My bad...lol. 1094 is the correct number...I work with too many numbers a day sometimes. Staring at a print all day and watching G code will make you number blind.
- psychomotors
All is well cgarb. I just couldn't pass up the chance to actually know an answer,lol. MadBill , BBF
My head said "F" but my finger thought it knew better and went with "C"
