Personal 380 SBC Dyno
Re: Personal 380 SBC Dyno
Chad, I would need all info on this page in reference to your head and flows at these specific lifts. I would be glad to type it in and post it for you. I think you have pinned the port energy on those heads at that port size. Thanks, Charlie
Chad, you have flow pipe used marked yes. If your exhaust port flows are from a pipe then you need to increase the port length and cc to include the pipe. I don' see any mistakes on your data input. I will check more after work. Thanks, Charlie
Ok, I think I figured it out but I am no computer genius. You changed the lifts so the program is multiplying as it is much less lift.
- BrazilianZ28Camaro
wow excellent numbers from 380ci!
The Wallace Racing Intake port mach index calculator give .6 mach and 435fps to these ports!
That's why you said these heads are choking the engine?
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
NEW BEST ET
323.3 ft/sec @.7" lift for the intakes and 321.6 ft/sec @.7" lift for the exhaust. No doubt they are crankin and the port energy is killer.
BrazilianZ28Camaro wrote:wow excellent numbers from 380ci!
Yes, I think it's out of port volume because the head is on the fast side of the induction.
Chad if you have the flows for lifts between .05 and .7" and put them into the program it works perfectly. I made up some flows for the missing ones and came up with some impressive graphs. Thanks, Charlie
Chad, I did some work on this and have some nice curves I can post if you like. Thanks, Charlie
Post it! Tell me what you see so I understand the program better.Carnut1 wrote:Chad, I did some work on this and have some nice curves I can post if you like. Thanks, Charlie
Cool, I would like to post my 247cc Darts on the same graph if you don't object. Very interesting, similar flows with much different port volumes. I should be able to post tonight. Thanks, Charliecspeier wrote:Post it! Tell me what you see so I understand the program better.Carnut1 wrote:Chad, I did some work on this and have some nice curves I can post if you like. Thanks, Charlie
I need to ask, if your exhaust flows are with a pipe I need the diameter of pipe and length to add into the program. I think those flows were without a pipe but I need to be as accurate as I can. If you have flows for .05", .15", .25", .35". I can add them in. I have already done the work estimating these numbers to get smooth curves. Thanks, Charlie
Chad Cnc 205 2.08/1.6 flow sheet. I needed to guess at .05", .15", ,25", and .35 " flows they were not included in Chad's original flow sheet. All the fun happens at higher lift anyway. I think these curves look pretty good.
