Bracket Engine, no maintenance was the plan.KnightEngines wrote:Cam looks like it'll live a long life, pretty mild on the lobes - low maintenance engine?
Did you try winding the cam back to 103ICL? - I reckon it may be happier there, but I may be wrong!
I can see 700hp pretty easy with another 4 deg duration on both sides, 103 ICL & slightly more aggressive lobes - say .430" lobe lift.
It's a damn good starting point as it sits!
Would be interesting to run it on E85.
The cam is in at 102.5ish. It has a .435 intake lobe, .422 exhaust. It needs more lift, IMO.. I wanted it to peak at 7-7200 with that stock block.
I say it ran out of head with 2.32in MIN CSA.
