Boring main support
Boring main support
Why would someone bore holes on each side of the main bearing support area,and does this cause this area to be weaker.
Re: Boring main support
yall need to look at some more drag engines and you will see more of this.
reed
reed
I believe the chevy LS series engines have this setup to relieve pumping forces
I get what they were attempting to do there, but bad idea in my opinion, somewhat depending on power level. I would have left the block structure alone and just put a vacuum pump on it.
That's a block for an NHRA Stock Eliminator engine....283/220 horse, to be exact.CGT wrote:I get what they were attempting to do there, but bad idea in my opinion, somewhat depending on power level. I would have left the block structure alone and just put a vacuum pump on it.
Vacuum pumps not allowed in Stock Eliminator.
I'm noticing the same spacer shells we use to install a 283 main crank into a 350 main size block. What's up with that?
Carlquist Competition Engines
tenxal wrote:That's a block for an NHRA Stock Eliminator engine....283/220 horse, to be exact.CGT wrote:I get what they were attempting to do there, but bad idea in my opinion, somewhat depending on power level. I would have left the block structure alone and just put a vacuum pump on it.
This engine is covered in a mag write up. Total story. That means it aint no slouch and it has won numerous numerous races and is done for a reason. Dont 2nd guess something you "aint" tried. If it works or not, it has won. Why it wins, I dont know but I bet the owner will tell you why.
reed
Another thing to remember about the NHRA Stock Eliminator engines is that they have to use the OEM or NHRA approved aftermarket oil pan. No box pans, kick outs, etc, etc., so any little gains are big deals.
I'm betting that it doesn't make much if any real difference in the strength of the block in the application. In other words the block is much stronger than it really needs to be anyway so even if it loses a small amount of strength it doesn't matter.
I thought something looked fishy, thats an early small bore bowtie block. No strength issues with such a low hp and cr engine.BILL-C wrote:I'm noticing the same spacer shells we use to install a 283 main crank into a 350 main size block. What's up with that?
These NA stockers with 1.72" Intake valves will never attain a level of HP where the weakining of the main web's will be a issue .
