Hi Steve,steve cowan wrote:Hey Scott,
Did you come up with any solutions on fuel pressure deal
I raced on Saturday night, run my radials on 18 psi
Passengers rear has turned about 10 mm on the bead
Have you ever had the same thing on yours
Steve c
I have never checked the bead so cant say if its ever moved.
I bought one of the Holley 170GPH mechanical pumps which has 1/2" inlet & outlets so now it has 1/2" from the pickup all the way to the reg which is 6" from the carby. It does still drop a bit which I expected to happen but very hard to tell while driving on the road. Need to video the guage while having a run at the track.
Was thinking about even fitting a 1/2" check valve near the fuel tank to stop any fuel that is in the line from draining back towards the tank on take off but not sure if I would be just wasting time.
