Keith Morganstein wrote:It's a (popular) myth that restricting flow makes the system cool better. Something about slowing the coolant flow lets the coolant pick up more heat. It's just not true, more flow moves more heat. (And less flow moves less heat). That's why we look for flow problems when there is high temp differential.
As far as pressure, yes there is the system pressure of the cap. There will still be pressure differential in the system. There is a suction side and a pressure side of the pump... Where there is restriction to flow, pressure differential will increase across the restriction.
Ok, got pressure differentials and was pretty much concerned about how low they are based on a few previous comments to this post. So, contacted Meziere and bounced this scenario and the gathered data so far, especially pressure differentials. Their tech, "Jerry" says as far as the overall pressure being low, this is not a problem. I also let him know we are not running a thermostat or a restrictor and he says this is fine, that we want max flow, period. I also let him know we had 1 3/4" engine water outlet, radiator inlet & outlet & water pump inlet. He has no problem with this arrangement either.
He also assured me that they have this pump out there on a lot of big block chevys on the street having no cooling issues.
