Put the pulley on there and check the cam timing with it on zero. Then take it off again and put it in the advance or retard position and check it again. I think you'll find that most of the three position sets do not move the cam timing four crank degrees but four cam degrees instead.Geoff2 wrote:Dave Mc,
I think you will find that '4*' is crank degrees. Example, If a cam is ground on 110 LSA with no advance ground into it, theoretically if the timing set was installed 'dot to dot' then the ICL would be 110*. If the the 4* adv slot is used on the crank sprocket, ICL becomes 106, ECL becomes 114. 106 & 114 are crank degrees, not cam degrees. The cam itself has only been advanced 2*, which translates to 4* crank..
A Cloyes timing chain set I have in front of me says: To advance cam 1*, use the 2* slot on the crank sprocket.
Cloyes directions are correct in that if you advance the cam one degree it is two crank degrees.
