Tuning up AFR 1040s opinions
mag2555
Re: Tuning up AFR 1040s opinions
Post by mag2555 » Wed Jun 14, 2017 1:50 pm
Lol, and I did not say zero low lift !
zums
Post by zums » Wed Jun 14, 2017 5:41 pm
cuisinartvette wrote:The .500 # was stronger than it was, held it to .550 didnt bother with any more you could hear the port wasnt liking it
I hear your agruemnts on both sides, know what I need to do now. Max rpm 6500 intakes done around 6ish
Owner is well aware not to pa much attention to # and may lose....heck they were off so why not type thing(doesnt expect much)
his intake will run out of steam before the cam/heads will
Another thing that can help your .5 and up numbers, assuming you have the ss sorted is the shape/ approach of the roof to the bottom cut, play with that and your upper numbers will increase, as was said , low lift is a waste of time, no ve boosts in low lift, especially if you dont have your valve job/ seat heights right
Tom
randy331
Post by randy331 » Wed Jun 14, 2017 7:15 pm
mag2555 wrote:You need a certain minimum amount of low lift Intake And exh flow to use the Cams overlap period to create as big a VE number as you can if the heads and or Intake Manifold on motor your dealing with is the choke.
How much do you need ?
A street SBC 383, operating from 3000-6500, pump gas, 10.8-1 comp, dual plane intake just matched up that is certainly a choke on the engine.
How much valve window area would it need at TDC for ex. and in. ?
How much flow at TDC would you need to make big ve ?
Tell me what you'd target for that.
CGT
Post by CGT » Thu Jun 15, 2017 2:00 pm
Stop trying to be so specific. :lol: Can't you just regurgitate what someone else is claiming or selling?
ZEOHSIX
Post by ZEOHSIX » Thu Jun 15, 2017 3:53 pm
You said your running a Accel/Ligenfelter Super Ram?.....Those things have a crappy port entry.....the manifold ports are far flatter than the cylinder head entry.....best gains would be made by getting rid of the intake for something better! Gawdawful! Intake design!
cuisinartvette
Post by cuisinartvette » Thu Jun 15, 2017 4:13 pm
Yes the old superram. Had an edelbrock base that has been heavily worked over
Tiny bit of welding so make all ports flow the same...theres 2 that are notoriously low
Hes stuck on using it, he knows a shorter runner will let the dogs loose just wants to see how far it can be taken the car moves out pretty well.
I agree a slight change in valve job could help but hes put enough in it going to run it as is so far;biggest problem has been people taking forever to get the simplest things done his driving season is running out
If the heads were mine id go farther...it was a barter deal and put enough hrs into this one. did try something with the roof that was expermental seemed to work out pretty well, doing the same thing -this roof bit I tried to another set didnt net the same result. Not getting into debates just brain pickin here
Thanks to those that offered up help.
randy331
Post by randy331 » Thu Jun 15, 2017 11:41 pm
Well, I'd like to know how much is necessary at overlap to not leave VE on the table.
And how you decide that.
Guess I'll never know. :(
RevTheory
Post by RevTheory » Fri Jun 16, 2017 9:45 am
What would you be looking for, Randy? Curtain area and flowz vs. piston position is something I've never been able to hear much about.
CGT
Post by CGT » Fri Jun 16, 2017 10:26 am
randy331 wrote:How much valve window area would it need at TDC for ex. and in. ?
.3921 CSA Intake .4605 CSA Exhaust?????? :lol:
randy331
Post by randy331 » Fri Jun 16, 2017 12:42 pm
How about a CSA of .3921 intake and .380 ex. ?? :D
zums
Post by zums » Fri Jun 16, 2017 2:21 pm
So you want a 2.02 to be at .096 lift @tdc with a 50* x .06 seat and a 1.585 to be @ .118 lift tdc on 50* x .07 ?
Tom
n2xlr8n
Post by n2xlr8n » Fri Jun 16, 2017 2:27 pm
When I was a kid the local fast country boy wore overalls with a button that said "I amaze myself".
You guys remind me of him (God rest his soul). :lol:
He also cracked himself up- one night he leaned into my friend's car window to talk trash- my buddy dropped the clutch, ran over his foot and the shoe flew about 40 ft.
He jumped up and asked us what we thought the 60' was.
psychomotors
Post by psychomotors » Fri Jun 16, 2017 2:30 pm
LOL #-o
randy331
Post by randy331 » Fri Jun 16, 2017 5:18 pm
zums wrote:
Tom
I wasn't saying that's what you need, but was asking if that's enough ?
It was stated you need a certain amount of flow at overlap and I was asking if that's enough csa at overlap to provide the needed flow.
And, 1.56 ex. valve :)
zums
Post by zums » Fri Jun 16, 2017 6:14 pm
randy331 wrote:
zums wrote:
Flow @ TDC,,, where do you want it, out the pipe or up the intake, thats easy just use the 128 rule :lol:
Tom
