Need Help On BBC Alumnium Heads For Street
- New Member
Needing to purchase a pair of Oval Port BBC Aluminum heads for a new build. It will be a 427. The pistons I picked are Keith Black KB176 and Howards CL 120245-12 roller cam. The car is a 69 Camaro with 4 speed. Last but not least wanting to run on pump gas. All help will be appreciated.
Re: Need Help On BBC Alumnium Heads For Street
i like trickflow imho best bang for the buck USA head.
- New Member
I'll take a look.....ThanksRacerrick wrote:i like trickflow imho best bang for the buck USA head.
- Show Guest
The AFR heads are much better for just a few more dollars
JOE SHERMAN RACING
JOE SHERMAN RACING
- New Member
bigjoe1 wrote:The AFR heads are much better for just a few more dollars
Thanks...
JOE SHERMAN RACING
Brodix has a lot of choices
- New Member
Could you recommend a part number?
JOE SHERMAN RACING
- Show Guest
Try # 3610-- Look at their website
JOPE SHERMAN RACING
JOPE SHERMAN RACING
- Alan Roehrich
You're doing this backwards. You don't pick pistons and camshafts before you pick cylinder heads.
- New Member
Do you have any suggestions on a very good tried and true street aluminum heads? Thanks.Alan Roehrich wrote:You're doing this backwards. You don't pick pistons and camshafts before you pick cylinder heads.
AFR or Brodix and you can't go wrong, in fact I think Brodix has a Summer sale going on!
- New Member
I'll take a very close look at them. Thanksmag2555 wrote:AFR or Brodix and you can't go wrong, in fact I think Brodix has a Summer sale going on!
If your Caming for peak power above 5500 I would go for the 290 cc heads if your running 3.90 or better rear gears, if not then the 265 cc head makes far more sence.
AFR has a roller spring set up option, I don't know about Brodix?
If this car has never seen a motor making over 400 HP then plan on up grading the fuel system a bunch before you yank full throttle out of the new motor!!!
- New Member
The owner wants a pump gas streetable 427 for weekend driving and car shows. The car is a very nice 69 Camaro Yenco tribute with Muncie 4 speed.mag2555 wrote:If your Caming for peak power above 5500 I would go for the 290 cc heads if your running 3.90 or better rear gears, if not then the 265 cc head makes far more sence.
It will have great streetablilty with the 265 CC or there about Heads.
