So? Which rod bolt is stronger?
shoedoos
Post by shoedoos »
Hypothetically, if I knew nothing about these three rod bolts....which one looks stronger? (Yes, I can check the stampings on their ends and look them up......that's not what I want to know though)
lefty o
Re: So? Which rod bolt is stronger?
Post by lefty o »
i like the one on the left.
cgarb
Post by cgarb »
One on the left looks like it has a larger underhead radius to me, plus it's more shiney and that has to be better.
Carnut1
Post by Carnut1 »
I like the design of the one on the left. Less theads not being used, shank is narrowed more so more of the bolt is used for stretch, bottom of the head has a thicker design, the shiney finish may mean there are less stress risers at a very small level.
Post by MadBill »
2X.
The larger underhead radius and making the shank diameter close/equal to that of the thread minimum diameter minimizes stress risers and should help fatigue life.
shoedoos
Post by shoedoos »
Just a little more info.....One of them is ARP, one is BME from ARP and one is MGP from A1....not in any order....
shoedoos
Post by shoedoos »
Here's the radius comparisons
GARY C
Post by GARY C »
Wow! the assumption response is mind boggling! I would say that the stronger one is the strongest but that would be a fact used in a theory based feeling world.
GARY C
Post by GARY C »
shoedoos wrote:Here's the radius comparisons
Now you have screwed up every ones assumption!
kosky racing
Post by kosky racing »
I will take a stab BME right MGP center ARP left
lefty o
Post by lefty o »
im sticking with my answer. 8)
Warp Speed
Post by Warp Speed »
kosky racing wrote:I will take a stab BME right MGP center ARP left
That would be my guess. I prefer the A1 bolt in the center.
shoedoos
Post by shoedoos »
mmmmm.....wish I had never mentioned the brands now.....
Post by MadBill »
Obviously we can't 'see' the alloy and its processing (e.g. double vacuum melt), heat treat, machining steps, etc., but based on design and finish I too think the left one is an ARP.
modok
Post by modok »
Use a file to see which is harder
